Old 07-04-2008, 11:42 AM   #1
Solidus311's Avatar
Oil Pan dent restricting oil flow?!
I've posted several posts and one thread about my low oil pressure. I think I may have found the problem. I just wanted to know if this dent is big enough to lower my oil pressure. The rb's pan is much deeper looking than an sr. But I don't know how far down the oil sump goes into it. You can see how long it is from the picture and I think it's about 1/2 inch to an inch deep.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 07-04-2008, 11:47 AM   #2
azndoc's Avatar
take it off and hammer it out.
azndoc is online now   Reply With Quote
Old 07-04-2008, 11:51 AM   #3
Solidus311's Avatar
Unhappy
Yeah sure beats the 125-150 for a new one. I was just trying to see if that could be the problem. I just changed the oil to see if that would help the pressure.
Could I just drain the oil into something and reuse it? I changed the oil like 10 miles ago.
Old 07-04-2008, 01:16 PM   #4
if you take the pan off you will see that the oil pickup sits less than a half an inch or so to the bottom of the pan. imagine a straw in a cup. now push that straw all the way flush to the bottom. its doesnt want to work right! you can take a mallet to your pan and try and bang it out but if you crack it your kind of screwed either way. one thing I would not be doing right now if I was you is starting/driving your car at all! think about it....NO OIL = NO MOTOR! good luck with it man.
TEAM SHAKE IT!
Atsugi, JP
dino6192 is offline   Reply With Quote
Old 07-04-2008, 01:32 PM   #5
Yea beat that out before its too late. I starved my motor of oil from the same thing.
http://wonvia.blogspot.com/
ms!3 is offline   Reply With Quote
Old 07-04-2008, 09:05 PM   #6
Solidus311's Avatar
Yeah thanks for the info. I'm lucky enough to have a daily driver too. I have not been driving the car at all.
Old 07-04-2008, 09:57 PM   #7
KwKouki's Avatar
Send a message via AIM to KwKouki
$125-150ish new oil pan or $1200ish SR motor......hmm choices
do it right the first time man
KwKouki is offline   Reply With Quote
Old 07-05-2008, 09:11 AM   #8
phi_ho1's Avatar
Send a message via Yahoo to phi_ho1
get a new one if but the dent one should be fine.
phi_ho1 is offline   Reply With Quote
Old 07-05-2008, 11:26 PM   #9
njd07's Avatar
Send a message via MSN to njd07
had the same problem with my sr...the pans get dented during transportation from japan...they fucking stack motors ontop of motors, etc. they dont give a shit so must of the motors have dented oil pans.
njd07 is offline   Reply With Quote
Old 07-07-2008, 08:02 AM   #10
s14unimog's Avatar
Send a message via AIM to s14unimog
use a 2x4 with a rubber mallet that way you don't stretch/ weaken the pan. Also hammer it against a piece of wood so that you don't scratch it. That will be your best bet to get it looking right again.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
SEO by vBSEO 3.3.0
