Old 06-12-2008, 10:04 PM   #1
GripSpec's Avatar
ka24e timing chain rebuild. replace front cover?
I have a 90 coupe that has a VERY loud timing chain. something obviously out of wack. I work at a nissan dealer (not a tech or mechanic) and when showing one of our service advisors my parts list, he said the only thing left out was the timing cover. He explained that it has water veins for the coolant that get worn down on cars with bad chains and needs to be replaced. Does this sound correct and in need of replacement? or really just not needed?
GripSpec is offline   Reply With Quote
Old 06-12-2008, 11:44 PM   #2
Send a message via AIM to frosti108
you need to take the cover off to know for sure if you need a new one or not. the chain only wears a hole in the cover if its been flapping around with broken guides for a long time.
a junkyard motor i got had broken guides but the cover was still fine...
89 240sx. 'turbo single'
88 200sx. 'se-v6'
frosti108 is offline   Reply With Quote
Old 06-18-2008, 01:42 AM   #3
infinitexsound's Avatar
pull and check... other wise dont buy a cover....till u know for sure...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-18-2008, 02:20 AM   #4
Marc240's Avatar
If you can't find a new cover like i couldn't, i ended up laying a nice bead of tig welding over the scrapped part of the cover.
You'll end up finding one probably though, cause thats only my luck
Marc240 is online now   Reply With Quote
SEO by vBSEO 3.3.0
