| | #1 |
| SR20DET timing chain marks So I am putting together my SR and i put the timing chain on and make sure to line everything up, but as soon as i rotate the engine over one complete revolution the timing marks are off by one chain link. Every rotation i do after this it continues to move one chain link per revolution. Obviously if i move the engine back it will line back up again and look perfect. Is it suppose to do this ? | |
| Sponsored Links | |
| | #9 |
| Zilvia Member ![]() | |
| | #10 |
| Thanks guys, I have the PDF and lined everything up as was instructed via the manual. The problem comes in when i rotate the assembly every full rotation from tdc to tdc of number one piston the marks are not lined up and they are exactly one chain link off and as i rotate the assembly it continues to move one chain link further away form the original timing marks. I was just curious about this and wondered if anyone else had observed this. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
