Old 05-27-2008, 02:30 PM   #1
sausage180's Avatar
aftermarket KA clutch
what's a good aftermarket KA clutch? i'm going to turbo it soon and am looking for the power range of 300-350. thanks
sausage180 is offline   Reply With Quote
Old 05-27-2008, 02:33 PM   #2
In time-out for misbehaving.
EDacIouSX's Avatar
Send a message via AIM to EDacIouSX
rps max 6 puck
Old 05-27-2008, 06:49 PM   #3
KA-T FTW
punxva's Avatar
Send a message via AIM to punxva Send a message via MSN to punxva
i'm running the Exedy 4 puck sprung clutch, holds 315 all day
-Punxva
Originally Posted by ThatGuy View Post
Cars are not MEANT to "run into shit".
Stupid fucking drifters.
Old 05-28-2008, 04:42 PM   #4
Drifterxxl180's Avatar
I have the SPEC 3+ and it's been grabbing hard and holding up well. Others may have had better luck with the Exedy had them wasn't to impressed started slipin quick. Also I wouldn't trust the E-bay crap
Drifterxxl180 is offline   Reply With Quote
Old 06-10-2008, 03:21 AM   #5
I love ACT, so I would suggest them. The actual kit depends on what exactly you want and what it will be used for. Here are some different options and Torque Capacities.
XTSS (Xtreme Street)- 333 ft/lbs
HDG6 (Spring Centered 6 Puck)- 342 ft/lbs
HDR6 (Solid Center 6 Puck)- 342 ft/lbs
XTG6 (Xtreme with Spring Centered 6 puck)- 426 ft/lbs
XTR6 (Xtreme with Solid Center 6 Puck)- 426 ft/lbs
Going with a 6 puck will not be as practical for street use due to the harsh engagement. I also did not include all of the kits, here is a link to all of the kits ACT offers.
http://advancedclutch.com/products/c...d_id=2298#2298
Meng1988 is offline   Reply With Quote
Old 06-12-2008, 12:37 PM   #6
Just something to think about. On KA24DE here are some options;
1.) 240sx Stock Flywheel size 225mm + After market clutch ++
2.) Nissan D21 Flywheel size 240mm + 300zx Non Turbo Clutch / Aftermarket +++
3.) RB20DET Flywheel size 250mm + 350z clutch / aftermarket +++++++
The point to these is the bigger your flywheel/clutch contact surface it will be less to none slippage and more torque it can handle. Just an FYI there are very minimal weight difference on all 3 flywheel. Plus, they can be lightened to whatever you like. GL!!!
eclipse_dsm is offline   Reply With Quote
SEO by vBSEO 3.3.0
