Old 05-20-2008, 09:47 PM   #1
surge s14's Avatar
Question gt2871r .64 taka line issue
im having a bit of a problem with my test fitting lines seem that the line on the waste gate aside not not getting along.
here im showing that the waste gate is not tightened down nether is the line so i can show you either way it is still in the way...
so am i doing something wrong?
i just looked up the hks actuator and its a nice fit since pole thing or whatever is straight.
also is there this much thread showing on this side?
thanks guys
so old looks like it needs life alert
surge s14 is offline   Reply With Quote
Old 05-20-2008, 10:12 PM   #2
SoguRacing's Avatar
Send a message via AIM to SoguRacing
mine didn't go in all the way either. i think it's normal, though there was a thread on this a while back. just whatever you do don't force it farther in.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-20-2008, 10:54 PM   #3
You can rotate the shaft on the actuators. Maybe the bend will give you the space you need.
I am the Negative Rep Master
Blown240sx is offline   Reply With Quote
Old 05-21-2008, 11:56 AM   #4
surge s14's Avatar
^i tried that already it seems too loose to me that is... im guessin that i might have to invest in the hks actuator :/
it also seems loose now im scared of tighting it
Old 05-21-2008, 12:28 PM   #5
slider2828's Avatar
You can't just bolt on the actuator tothe turbo for SR20s. You need to test fit i on the flapper as well. As I remembered it I pounded the crap outta the plate that holds the wastegate. I never had a problem with the lines. As per the threads, that looks about right...
MAKE SURE YOU GET A OIL RESTRICTOR.....
Turn and Burn!
Old 05-22-2008, 11:06 PM   #6
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Umm...you can re-clock the center to keep the water line away from the actuator arm. You tried that yet?
Old 05-22-2008, 11:19 PM   #7
SoguRacing's Avatar
spin the actuator rod the other way so the line has more space..should work. you shouldn't have to do any hammering to the flapper. just use some common cents (.02) and figure it out. it isnt that tough. 100's of other people have done the same thing with the same setup.
Old 05-22-2008, 11:38 PM   #8
golfer17's Avatar
Send a message via AIM to golfer17
I couldnt get my ss line to fit with the 90 going to the turbo either, but i did find that with my i/c and inlet piping, it fit really well with the 90 going to the coolant neck and the straight fitting into the turbo.
golfer17 is offline   Reply With Quote
Old 06-12-2008, 10:27 PM   #9
sidewaysil80's Avatar
+1 or 2 i just rotated the arm and had plenty of room
sidewaysil80 is offline   Reply With Quote
Old 06-12-2008, 11:21 PM   #10
SoguRacing's Avatar
awesome! good job!
SEO by vBSEO 3.3.0
