Old 05-16-2008, 02:59 PM   #1
Tearlessj's Avatar
Heater hose solution for SR swap?
What should I do for the heater hoses for my swap? Anyone have part numbers for what to get at the Auto store? Any info would help. I rather not get the Heavy Throttle kit cause I want this done this weekend. Thanks!
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 05-16-2008, 03:02 PM   #2
240trainee's Avatar
Send a message via AIM to 240trainee
I think I have the parts numbers saved somewhere, I'll look.
There's no perfect solution, but there are some that work
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 05-16-2008, 03:08 PM   #3
best think to do is to cut the heater tube where it bends and under the intake manifold and clamp the heater hose to it, or braze on an AN fitting and run an AN barb and use socket hose or summit "twist tite" hose to the heater core, then tap ur water neck for the coolant return for the turbo, or get s14 water neck.
japslapsilvia is offline   Reply With Quote
Old 05-16-2008, 03:24 PM   #4
Sileighty_85's Avatar
From Car Quest the Part #'s are
19619
19628
these are the exact ones from enjuku
http://enjukuracing.com/heater-hoses...ml?cPath=24_56
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 05-16-2008, 04:08 PM   #5
Tearlessj's Avatar
19619
19628
Have you used them before? I know some people have had issues with the Heavy Throttle ones.
Nagasaki Motors
Old 05-16-2008, 05:38 PM   #6
Send a message via AIM to thestreetzking
i went to autozone and jus looked at all the hoses and made something work, for the top one i believe i just looped it around from where it was and then the bottom one was just a small straight
thestreetzking is offline   Reply With Quote
Old 05-16-2008, 06:43 PM   #7
I never thought this was a big deal. We always made the factory ones work by moving them around a little.
I am the Negative Rep Master
Blown240sx is offline   Reply With Quote
Old 05-16-2008, 06:56 PM   #8
Yes I have them on my SR right now they work but if i could i would extend the center by 1 in, but they work just use new clamps with them
後輪駆動車1番
Old 05-16-2008, 07:21 PM   #9
g6civcx's Avatar
If you searched my post, you will find the exact part numbers found in the Heavy Throttle kit.
Although some people swear by the HT kit, I recommend making your own because the S hose on the HT kit is 3/4" all the way through = leak at the 5/8" heater core fitting.
Old 05-21-2008, 03:08 PM   #10
I just went to the autoparts store with a mock drawing of the curves I wanted...got like 1 or two random hoses and then a couple of couplers from a heater hose repair thing they had for $4. I think in all I spent like $13.
turbocarslut is offline   Reply With Quote
Old 05-27-2008, 04:34 PM   #11
codyace's Avatar
The HT kit works, as they have an barb push on adapter to go from the small hoes to the bigger hose.
HOWEVER I am NOT a fanof the blastic barb. Wihle some have had no issue, I had two of them melt and brake on me, causing near overheating the engine, as well as a mess.
Since then, I made my own out of brass fittings that shared a similar NPT end, and a bushing. No problems, 6 or 7 HPDE days, and street driving later.
Want Air Conditioning in your SR 240? PM me for Adapter Plates!
Old 06-16-2008, 01:22 PM   #12
Go to autozone or order online.
"L" shape part # S-3009
"S" shape part # S-3026
SRpetey is offline   Reply With Quote
Old 06-16-2008, 09:21 PM   #13
g6civcx's Avatar
You're describing the U hose. There is no issue with this.
The problem is the S hose. Like I've posted many times before. This hose from the HT kit is 3/4" through and through. It fits the SR block fine, but 3/4" on a 5/8" heater core fitting = leak.
SEO by vBSEO 3.3.0
