| | #1 |
| BANNED ![]() | help with turbo and fuel how is it a s14 sr uses the same T28 turbo but 370cc injectors, whereas the s15 uses I think it was either 444cc or 475cc injectors. Are the 370cc injectors which I have on my s13 sr going to be adequate at stock psi levels with the s15 turbo? |
| Sponsored Links | |
| | #3 |
| Leaky Injector | Why would the bigger turbo make it run rich? If anything it might run leaner if you push the s15 turbo to max psi with I think on those GT28rs is 16 psi. Watch the A/F with a wideband and see how it does. You might come close to maxing those 370s out.
__________________ I am the Negative Rep Master |
| | #5 |
| Premium Member ![]() | I think he just misspoke guy two posts up. If you swap the 440's I think those are S15 injectors, you will run rich as the stock computer won't compensate to the new injectors. If you run S15 turbo with stock injectors 370's, you will be fine... Most injectors from the factory only run about 60-70% of capacity at stock boost. if you push 10psi, its about 70-80% and at 12psi about 80-90%. But anything over 12psi is about 100%. Not a good idea... OBVIOUSLY this all depends on tuner.... these numbers are just rough idea..... as an example...
__________________ |
| | #6 |
| Leaky Injector | Most of the time 85 injector duty is pushing it but I know some tuners who go for max power and will set there injectors up in the computer to run at higher than 100% by setting their injector numbers higher. Its up to the tuner though. Im a big fan of safe when it comes to fuel systems.
| | #7 | |
| Quote:
| | #8 | |
| SLINKY + ESCULATOR = Fun Times ![]() | Quote:
IIRC, as far as the difference between a S14/S15 Spec S T28 vs the S15 Spec R T28 is that the Spec R are dual ball bearings with a divider in the exhaust housing. Also, S14 T28s are iffy, some are ball bearing, some are journal bearings. Can't remember exactly how you can tell what the turbo is exactly, think the best way to do so is by looking up the part number...
__________________ | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
