Old 04-17-2008, 04:27 PM   #1
Goinsleeper's Avatar
s13 Odd CAS problem
I pulled my harness and cut everything to length for a wire tuck. I get done and put the harness in the car. First thing i do is check for codes and im getting an 11. I fiddled around with some stuff and had no success so i decided i would take the easiest route first and check to make sure it was grounded properly. I cut the ground i had running to the cabin and made a new one that just ran to the chasis right next to the CAS. I check my codes and get a 55. so i tried starting the car and it wont start up. i check codes again and get the 11 again. i decided my 2 second ground replacement could be crap. so i made a more solid ground and wire it up and im back to a code 55. i try firing the car up with no success and get a code 11 again. i pull the key completely out and tinker, code 55 again. try to start the car, another 11. the ground i put on it is SOLID. i dont get why the ecu is going back and forth and the freakin codes... any ideas?
96' 200sx stock GA ownage(chirpin 3rd)
92' 240sx SR'ed
~motor's back in!
Goinsleeper is offline   Reply With Quote
Old 04-19-2008, 09:23 PM   #2
Does my logic work? Could it be that when i put the key in that the ECU is grounded properly and then when i try to crank the car there isnt enough grounding for all the electronics and so the ECU basically throws every code? i mean, CAS code is 11 and thats the first code. would it make sense that if the ecu was to throw every code, it would start with the first?
92' 240sx SR'ed
~motor's back in!
SEO by vBSEO 3.3.0
