| | #1 |
| 97 Kouki. On going project... ![]() | KA24DE Problem... Came from nowhere. I was driving my car the other day..headed home. Well my oil light flashed on and has i was making the corner went off. Well im almost home and the miles per hour start dropping and at first i just thought maybe my foot was to relaxed so i gave it a lil gas and the mph still dropped. Then i heard some sort of scraping type bullshit from the engine bay..not to loud but definetly noticeable. I turned onto my road and the car died. I get it home and try to turn the key and the motor acts like it wants to crank but just wont. I check the oil dipstick and it is almost bone dry. To my knowledge the car has no oil leaks anywhere. Anybody have any idea? Should i just drain all the crappy oil out and replace with new oil and give it another shot or is there something seriously wrong with her? Car is a 1997 s14..motor has given me absolutely no problems till this. It has about 130k miles on the motor. Its also an auto if that matters. Thanks for any help.
__________________ |
| Sponsored Links | |
| | #2 |
| Has a Premium Member. ![]() | When was the last time you changed or checked the oil before this? sounds like you had a leak and let it run dry or you were burning oil very fast.
__________________ ![]() ![]() |
| | #6 |
| Leaky Injector ![]() | i agree with what murda-c said. if there was a scraping sound u probably need to rebuild it because bad noises from inside ur engine are usually correlated to damage. it would be better to rebuild it just in case before u try to crank it up again, because if u crank it up and whatever was scraping isnt inspected/fixed ur gonna ruin ur engine completely if its not already |
| | #7 |
| 97 Kouki. On going project... ![]() | well im not exactly sure how to rebuild a motor...ive never done it before but i mean..it couldnt be to to hard.How do i go about doing that?Is there a way i can check the motor now before i take the chance of messing it up even more?
| | #8 |
| Has a Premium Member. ![]() | have you drained the oil yet? check the oil for metal particles. If it looks sorta like glitter paint, you're going to need some kind of rebuild. Open the valve cover and check the cams out. http://www.zeroyon.com/index/content/view/24/47/ get a factory service manual from there for torque specs and sequences if you want to take the cam caps off and look at those journals.
| | #9 | |
| The Cook ![]() | Quote:
cuz if there chunky shit in there...u need a rebuild ![]() | |
| | #13 |
| 97 Kouki. On going project... ![]() | Damn. What all would I need for a rebuild if it came down to it? And most importantly..where would I find all the things i would need? Parts store? Dealership?
| | #15 |
| boostin!!! ![]() | Just for you, not sugar coated. If you go to a stealership for a rebuild it will be around 2500-3000 plus labor. So 4k+ If your motor is reusable/doesn't have a ruined crank If you can pull and reinstall the motor your self and put the head and timing stuff on........ Figure around $1000 For(timing kit, oil and water pumps, thermo, gasket sets, bearings other random things) $500 the engine work(machine shop, assembly....) If you damaged your cylinder walls add 3-400 Used KA Under $500 plus the cost of fluids and what ever maintance you want to do to it before you put it in.
__________________ 1990 240sx KA-T Best 1/4 mile ET: 12.5 Best 1/4 mile MPH: 117 2003 WRX Sedan PSM Stage 2 with lots of suspension and brake mods ![]() Now owning 240sx #11 ![]() R.I.P. 1quick4 aka Chirs |
| Sponsored Links | |
| | #16 | |
| Leaky Injector | Quote:
__________________ I am the Negative Rep Master | |
| | #17 | |
| Zilvia Addict ![]() | Quote:
Honestly, rebuilding a motor is intimidating, but just take your time remember where things go, get a fsm, obviously and it's pretty much cake. If you dont feel comfortable a machine shop will do it, if you give them all of the parts for maybe 300$ or so. one thing to learn about cars, always expect the worst cause if it comes out to be, you wont be as dissapointed. | |
| | #18 |
| 97 Kouki. On going project... ![]() | Yea i think this bitch is pretty much toast. Im not even gonna try to rebuild it. No KA is worth getting into the thousands of dollars to have fixed imo. Junkyard here I come
| | #19 |
| Leaky Injector | aww man down dis ka's like that..there pretty well built engines i just rebuilt mine..if well taken care of and driven good they will last forever..and today with the gas prices knockin at 4 bucks a gallon..the ka's are decent on gas mileage or u could just slap in a eletric motor and 14 batteries and run forever |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
