| | #1 |
| Premium Member ![]() | IACV Plug... What's actually needed? So in my harness simplification process I've pretty much got everything figured out(I think), but am unsure about the IACV plug. It has four wires going into it. I've come to the conclusion that I *should* only need two of these four. The light blue wire(signal) and the black/yellow wire(power). Am I right on this? The other two wires seem to be part of the AC. The other two wires are blue/green and blue/red. Can anyone confirm? TIA. Last edited by JVD; 04-13-2008 at 03:55 PM. |
| Sponsored Links | |
| | #2 |
| @RPSport.net! ![]() | From my understanding you only need the 2 wires + and - to pulse it on and off. The other wires list as going to the ac compressor, probably for a secondary position in the AAC when the A/C is switched on. So if you are not using A/C then You could probably drop those.
__________________ RPSport 949.891.1710 RPSport's New Products for the S13 and SR20! Join our Haltech Group Buy! John@RPSport.net |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
