| weird electrical issues, yet runs good??? I'm having an odd problem with my s13. I did the sr swap and it runs fine. at the same time I stripped the interior and welded in a cage. put everything back together and there's no dash lights, idiot lights, signals, heater fan, headlights don't go up ect. pulled the dash back off and triple checked the wiring, grounds and still nothing. The sr ecu was bent up, but I figure it should be good if the cars running fine???
Found the problem, it was a bad 75amp fuse in the engine bay :hammer:
Reason: fixed
