Old 04-04-2008, 07:43 PM   #1
timtiminy's Avatar
Send a message via AIM to timtiminy
SR head rebuild (rocker arms)
hey guys i am rebuilding my sr20det completely and got a complete set of new rocker arms to replace the ones that were on the head as they were gouged by the camshaft cause somehow it looks like molten aluminum plugged up the little oil squirters on the rocker arms... question is, will I have to reshim for the new rocker arms or because i am using the stock automaticaly adjusting hydraulic lifters will they be fine leaving them as is? I am also wondering if there is a way to test the hydraulic lifters to see if they are in good working order?
thanks for your help,
Tim
timtiminy is offline   Reply With Quote
Old 04-04-2008, 09:42 PM   #2
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Umm...have you thoroughly checked the whole head to make sure nothing else is fucked up? Usually if the rocker arm gets gouged by the cams, theyre both done and something else may be fucked up too since oil wasnt properly flowing in the head. SRs are so dependent on oil its not even funny.
But to answer your question, you shouldnt have to do anything else other than making sure all the lil magnetic valve caps thing are all there.
Old 04-05-2008, 12:03 AM   #3
timtiminy's Avatar
yeah i checked out everything else, seems like everything else is good. the cam lobes are blued but other than that the cam bearings/caps are good no gouging there. I dont really understand what happend with the little holes on the rockers getting plugged.. it only happened on the intake side and nothing else is damaged. would it be safe to use the camshafts with the lobes blued? I may just look into some 256 cams i just dont want to move my torque curve up in the rev range. oh and if anyone knows how to check hydraulic lifters please chime in.
SEO by vBSEO 3.3.0
