Old 03-13-2008, 03:06 PM   #1
Anyone know where this wire goes ?
Does anyone know where the yellow wire from the purple plug go ?
I think the red plug is the AAC but the purple one I dont know.
Many thanks in advance
Paul
Paulpen is offline   Reply With Quote
Old 03-13-2008, 07:57 PM   #2
Sileighty_85's Avatar
Its been awhile since Ive worked on an RB
If it like an SR there are coolant lines that run through the IACV
The Purple one I believe is a Coolant sensor for the IACV so it can adjust to the change of the engine temp. for Idle A/F Ratios
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 03-27-2008, 11:35 PM   #3
BIZERK's Avatar
Send a message via AIM to BIZERK
the one with the purple plug is the FICD. The FICD is only need when you have the AC on. so if you aren't going to be installing AC, i wouldn't worry about it.
BIZERK is offline   Reply With Quote
Old 03-28-2008, 12:56 PM   #4
Thankyou
Old 03-29-2008, 09:50 AM   #5
Just an idea but can I somehow wire it so that it ups the idle when my elec fans cut in ?
Old 04-14-2008, 04:28 AM   #6
ichibans13's Avatar
You would have to splice the power to the power of your fans (after the switch) and the ground to a grounding point. Then, when your fans are getting power that will get a signal to kick on.
|OO\____/OO| Okinawa JP 2003-2006
Currently: R14 -- Carolina Nissans Elite
ichibans13 is offline   Reply With Quote
Old 04-14-2008, 12:20 PM   #7
May well give that a test go before I tape it all up nicely then
SEO by vBSEO 3.3.0
