Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 07-06-2009, 11:46 AM   #1
Chops@MVP's Avatar
Send a message via AIM to Chops@MVP
Wideband and Electronics SALE at MVP!!!
If you are in the market for any Wideband or Electronic product message me. We are a supplier for every Major brand in the automotive community. We carry products from AEM, PLX, Innovate Motorsports, Greddy, HKS, DEFI, Blitz, and many more.
MESSAGE OR CALL ME FOR BEST PRICING.
We have ALL Innovate products on sale.
LM-2 -- Basic Kit retails for $349. The new LM-2 "Basic" Kit (Single Wideband O2) ONLY includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide.
DB Gauges in Red or Blue retails for $229.
The industry's most accurate and fastest responding wideband controller
One additional analog output
Easy setup and wiring
LC-1 includes Innovate serial in and out for adding additional modular tuning system (MTS) components
Blackout appearance when not powered
Log directly from the LC-1's digital output into laptop with included software
Includes LC-1, Oxygen Sensor, O2 Bung, and of course the blackout DB gauge
XD-16 retails for $329.
The XD-16 ships as an Air/Fuel Ratio gauge, but can also be configured to display any channel in the MTS chain or it can be connected to the LM-1. The XD-16 features programmable LED colors and a remote control button to start and stop log sessions, initiate calibrations, or view min/max values.
  • 2 Bezels + 8 faces = 16 combinations (see below)
  • 3/4 thick, so it's possible to mount even in surface mount configurations
  • Fits 52 mm (2-1/16") gauge pods
  • 3-character LED display
  • Record/Calibrate/Peak Hold button
  • Programmable (values and colors) digital needle
  • Billet Aluminum bezel
  • The basic kit ships with both black and silver bezels, 8 faces (AFR, Pressure, Temperature, and blank).
  • MTS compliant
The XD-1 can be customized via a Web Based print tool. You can choose any unit of measurement, various fonts, upload an logo (or other graphic), and then print the high-resolution scaled image directly onto transparency paper. Use you included blank faces, overlay the clear cut out, and you've got a custom gauge face!
The XD-16 is also a key component of Innovate Motorsports' Modular Tuning System (MTS). Using the XD-16's serial ports you can daisy-chain other Innovate devices such as the LC-1, AuxBox (LMA-3), DL-32, TC-4, and SSI-4.
The XD-16 Gauge System can be purchased separately for $229 as an accessory to be used with the LM-1 or with any of our MTS compatible units. This kit includes the XD-16, mounting hardware, serial cable, CD and quick-start guide.
This Standalone Gauge Kit comes complete with the patented award-winning LC-1 Wideband Controller, XD-16 , Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
Installation and Setup
Installation of the XD-16 is relatively simple. Complete documentation is supplied, and the support pages, user forum, videos, application notes, and tuner resources can also speed you on your way to effective tuning.
G2, G3, and G4 Gauge Kits
G2 AFR Gauge Kit
The G2 Air/Fuel Ratio gauge (52mm, 2 1/16? features a high-speed stepper motor, through-dial backlighting, and an illuminated pointer. Each kit includes the gauge, an LC-1 wideband controller, oxygen sensor & bung/plug, and the award-winning LogWorks engine-tuning software.
Key benefits of the Ũ2 kits include:
- The industryÃÔ most accurate and fastest-responding wideband controller
- One additional available analog output (one connects to the gauge)
- Easy set up and wiring (instructions included)
- LC-1 includes Innovate serial in & out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial)
- Illuminated needle and through-dial backlighting
- Log directly from the LC-1ÃÔ digital output into laptop w/included software
G3 AFR Gauge Kit
Innovate Motorsports is releasing a new 52mm (2 1/16? gauge- the Ũ3 Air/Fuel Ratio gauge. The G3 features a high-speedstepper motor, through-dial backlighting, an illuminated pointer, and retails for $289. Each kit includes the gauge, an LC-1 widebandcontroller, oxygen sensor & bung/plug, and the award-winning LogWorks engine-tuning software.
Key benefits of the Ũ3 kits include:
- "Blackout" appearance when unpowered
G4 AFR Gauge Kit.
The G4 gauge kit contains the same componenets as the G2 and G3 kits with the updated G4 Gauge.
AEM
AEM UEGO Retails for $388.75.
AEMÃÔ Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit!
AEMÃÔ Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED ÅÏeedle that changes colors as AFR changes from rich to lean. The unitÃÔ 52mm (2-1/16? gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features:
Bosch sensor included!
24 Color-coded LED display lights provide immediate reference to engineÃÔ air/fuel ratio AFR
Integrated three-digit display reveals AFR in real time
User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
AEM Tru-Boost gauge type controller retails for $419.50.
AEMÃÔ TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. ItÃÔ that simple, and IT WORKS!
AEMÃÔ TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEMÃÔ boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it wonÃÕ corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
For Unbeatable Pricing Call or Message Me Today.
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Master Distributor for : RPS, Tein, Seibon, C's, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, ARC, Volk, Fidanza, Defi, ....and so many more!!!
Chops@MVP is offline
Old 07-06-2009, 12:49 PM   #2
lewisfk's Avatar
price tru boost guage shipped to 78336
lewisfk is offline
Old 07-06-2009, 12:52 PM   #3
JohnnyDrfiter22's Avatar
Price on AEM UEGO, and G4
JohnnyDrfiter22 is offline
Old 07-06-2009, 01:09 PM   #4
Chops@MVP's Avatar
PM's sent/replied to!!
Electronics specials are not limited to the items in the pics guys so if there's something else you have had your eye on electronics wise don't hesitate to ask!!!!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-06-2009, 03:57 PM   #5
do you carry the whole line of AEM electronic gauges?
looking at AEM Wideband, AEM True Boost, Oil Pressure, Water Temp.
Thanks.
bradystrib is offline
Old 07-06-2009, 04:38 PM   #6
Chops@MVP's Avatar
Yes sir I do! Please PM me with exactly what you are after and your address to get you that quote together!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-07-2009, 10:23 AM   #7
Chops@MVP's Avatar
All PM's replied!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-07-2009, 11:03 AM   #8
Send a message via AIM to slideways2004
truboost to 77089?
slideways2004 is offline
Old 07-08-2009, 10:55 AM   #9
Chops@MVP's Avatar
PM sent!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-09-2009, 01:39 AM   #10
Chops@MVP's Avatar
All PM's replied!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-09-2009, 03:13 AM   #11
hpipro4's Avatar
Trader Rating: (39)
aem water temp shipped to 95616?
hpipro4 is offline
Old 07-10-2009, 10:43 AM   #12
Chops@MVP's Avatar
PM on the way. Thanks for all the orders everyone!!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-10-2009, 04:05 PM   #13
Chops@MVP's Avatar
STARTING TODAY TILL NEXT FRIDAY, RECEIVE FREE OVERNIGHT SHIPPING ON ANY AEM ITEM AND FREE 2 DAY SHIPPING ON INNOVATE!!!!!
If a speedy delivery isn't that important to you feel free to have a $10 MVP Gift Certificate to be used on future purchases.
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-14-2009, 12:44 AM   #14
Send a message via AIM to jivetoast
the tru boost and aem wideband to 08723 please
jivetoast is offline
Old 07-14-2009, 02:05 AM   #15
hpipro4's Avatar
Trader Rating: (39)
aem fuel/oil pressure gauge shipped to 95616?
thnx
hpipro4 is offline
Old 07-14-2009, 12:11 PM   #16
Chops@MVP's Avatar
PM Sent!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-16-2009, 12:03 PM   #17
Chops@MVP's Avatar
All pm's replied!! Thanks for the orders guys!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-17-2009, 06:52 PM   #18
Chops@MVP's Avatar
G5 Gauges have been discontinued!!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 07-24-2009, 04:48 PM   #19
Chops@MVP's Avatar
TTT!!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 08-03-2009, 06:52 PM   #20
808DRFTR's Avatar
aem tru boost to 85240
808 All Day, Livin The HILIFE!
808DRFTR is offline
Old 08-04-2009, 10:01 AM   #21
Chops@MVP's Avatar
PM sent!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
Old 08-04-2009, 07:18 PM   #22
ColumbusDrift's Avatar
Does the DB gauge kit come with everything that I need to monitor AFR? Can I do AFR logging and still have the gauge display?
Price of DB gauge kit shipped to 48197 please?
Thanks.
96 S14 SE with T25 KA24DET
ColumbusDrift is offline
Old 08-05-2009, 10:19 AM   #23
Chops@MVP's Avatar
Yes sir you are able to log AFR with the included software. The DB Gauge is a full kit with everything necessary to monitor and log AFR's.
PM coming shortly with pricing!
Regards,
Robert
MVP Motorsports
940-683-8282 x20
Robert Del Angel
SEO by vBSEO 3.3.0
