Old 12-10-2004, 12:43 AM   #1
My240sx's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
5 lug hub question...its not about fitment
i've been looking for 5 lug hub swap for my 92 240 and i came across this.... http://www.performancenissanparts.co...oducts_id=1161
I called and asked if the fronts would bolt directly onto my 92 and they said "yes"....so whats the difference between these hubs and the attain hubs
My240sx is offline   Reply With Quote
Old 12-10-2004, 01:09 AM   #2
BobbyBoy's Avatar
Send a message via AIM to BobbyBoy
Thats what I want to know too...and am too lazy to search
BobbyBoy is offline   Reply With Quote
Old 12-10-2004, 01:11 AM   #3
Trader Rating: (67)
Feedback Score: 67 reviews
I think these are stock 95-98 se hubs.
They probably dont know that these arent a simple bolt on for other years.
rancid240 is offline   Reply With Quote
Old 12-10-2004, 01:15 AM   #4
My240sx's Avatar
Trader Rating: (18)
but on the page it say's for 4 to 5 lug swap you need 2...and i called them today and asked if it would fit on my 92 without any other parts and they told me "yes"
Old 12-10-2004, 02:31 AM   #5
evilimport's Avatar
I think you are right....if they get you to buy them...their job is done. And I dont think those hubs come with the bearings either...so you'll have to get them pressed....and I believe you'll need S14 spindles to make the swap work.
You douche bags bring your A-game?
S14 Zenki face owns all.
evilimport is offline   Reply With Quote
Old 12-10-2004, 02:32 AM   #6
It's kind of sad when a Nissan dealer lists the WRONG INFORMATION.
S14 front spindle uses a 32mm nut.
S13 front spindle uses a 30mm nut.
-alex
mav1178 is offline   Reply With Quote
Old 12-10-2004, 02:34 AM   #7
And to answer your question directly....
These front hubs are S14 front hubs. They WILL NOT FIT TO S13 SPINDLE. WILL NOT. And they are not the same as Attain hubs.
To recap:
Attain hubs fit to S13. Same with GTO hubs.
S14 only need OEM 5 lug hubs for the front. And they only fit to S14.
Rears are all interchangeable, S14 5 lug and Z32 nonturbo.
-alex
Old 12-10-2004, 02:36 AM   #8
Um,
OEM S14 5 lug hubs have bearings pressed into them.
New studs, too.
I have a pair at home. Have to return them to Superior Nissan.... never got around to using them.
-alex
Old 12-10-2004, 02:45 AM   #9
My240sx's Avatar
Trader Rating: (18)
ok thanks guys, yea i've done a decent amount of reading up on the 5 lug hub swap and i thought it was weird to see them for so cheap...but your probably right its only for the S14 4 to 5 lug swap
Old 12-10-2004, 02:56 AM   #10
SilviaDriver's Avatar
Send a message via AIM to SilviaDriver
mav1178 is correct. these are s14 SE hubs ONLY!! studs and bearings are pressed. i juss recently bought these from another dealer about 2 weeks ago...brand new front hubs sitting on the ground
if you want..buy them here..they got free shipping for december. when i bought it from them shipping came out to be like 8 bucks total
http://www.trademotion.com/partlocator/?siteid=214024
SilviaDriver is offline   Reply With Quote
Old 12-10-2004, 03:03 AM   #11
Actually I want to be explicitly clear.....
I AM RIGHT.
I know because I HAD Attain hubs on my S13, then I changed my entire front setup to S14 spindles/hubs with S13 LCA and S14 ball joint pressed in, with sleeves machined for the S13 strut.
I speak from experience.
Or read here: http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Or quoting what I wrote:
-S13 uses 30mm front hub bolt, S14 uses 32mm front hub bolt. Both chassis uses 36mm rear hub bolt.
-Conversion to 5 lug on S13 chassis requires S14SE/Z32nonturbo rear hubs, and either 1) JDM aftermarket front S13 5 lug hubs, or 2) S14 SE front hubs + S14 spindle + S14 ball joint w/LCA (and redrilling of strut for larger strut bolt).
-Conversion to 5 lug on S14 requires S14 SE front hubs and S14SE/Z32nonturbo rear hubs.
And some info on using S14 front spindles on a S13:
http://forums.freshalloy.com/ubbthre...fpart=all&vc=1
-alex
Old 12-10-2004, 04:20 AM   #12
Send a message via MSN to GT-RPS13
i researched into this b4 i swapped mine. this info was taken from sillbheer's website
For S13 Rear:
S14 SE or Z32 N/A Hubs
S14 SE Rotors (or 4 lug rotors re-drilled to 5 lug)
5 Lug Wheels
For S13 Front:
S14 SE Hubs
S14 SE Spindles
S14 Ball Joint (will need to be pressed into your existing S13 Lower Control Arm)
5 Lug Wheels
if you are planing to convert the fronts i HIGHLY suggest just gettin aftermarket conversion hubs (Attain, GTO, Signal Auto ect.) thats what i did. it will save u money and its all you need for the conversion and alot less work. as for the rears all you need are the hubs and rotors
or if you are looking for a cheaper way you can just buy 4 to 5 lug 15mm conversion spacers and save on labor. unless u own a wheel bearing press
GT-RPS13 is offline   Reply With Quote
Old 12-10-2004, 07:03 AM   #13
WOW addicted
sykikchimp's Avatar
Send a message via AIM to sykikchimp
good info guys... It's probably already there, but.. off to the FAQ it goes..
sykikchimp is offline   Reply With Quote
Old 12-10-2004, 07:29 AM   #14
MakotoS13's Avatar
Send a message via AIM to MakotoS13
yeah people talk about the swap process a lot but it isn't exactly well known that S14/NA Z32 hubs fit the rear and attain/GTO hubs are fore the front THUS making the purchase of rear attain/GTO hubs a waste of money.
MakotoS13 is offline   Reply With Quote
Old 12-10-2004, 01:55 PM   #15
mr_240sx's Avatar
where do i find the FAQ?
regular membership sucks!
mr_240sx is offline   Reply With Quote
Old 12-10-2004, 02:00 PM   #16
WOW addicted
sykikchimp's Avatar
go to forum index and look for "Archive/FAQ" under "Specific Topics"
Old 12-10-2004, 03:25 PM   #17
Send a message via AIM to final act
attain is aftermarket hubs meant for easy 5 lug.....those are oem 5lug hubs that wont fit on your 92 240sx unless you have the s14 spindle and s14 ball joints pressed into your s13 arms
final act is offline   Reply With Quote
Old 12-10-2004, 04:12 PM   #18
i posted the original thread on my buddies name but anyway....
final act...yea i now realize that....goodtihng i posted this b/c i called and they gave me the wrong info..and i would have been SOL if i would have gotten them from preformence nissan parts...hopefully this thread will help out other people who were asking the same question
pqsoccerboy17 is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
