| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | #1 |
| Zilvia Member ![]() Join Date: May 2012 Location: Somewhere Age: 20
Trader Rating: (0) Feedback Score: 0 reviews | PBM comp question Got my PBM competitions today I mounted the rear fine when I went to throw the fronts on I mounted the tops fine and when I got to the lower hub bolts the pbm hole to fit the bolt through is too skinny to fit the OEM size bolts... Any suggestions? The car is s13 hatch |
| Sponsored Links | |
| | #3 |
| Zilvia FREAK! ![]() Join Date: May 2007 Location: Kansassszsz Age: 25
Trader Rating: (1) Feedback Score: 1 reviews | Do you maybe have s14 lower control arms? Because you might also have s14 hubs, which would mean you have a larger bolt for that. I'd just get a 14mm IIRC drill bit and fix'r up. Or contact PBM and see about getting s14 lower mounts. Definitely double check though.
__________________ |
| | #7 |
| Zilvia FREAK! ![]() | Just go get s13 bolts. I have the same setup and got a spacer so I could use the s13 bolt on s14 knuckles with no play. Otherwise, just drill out the hole.
| | #8 |
| Zilvia Addict ![]() | i don't know for sure. but you should call the konig distribution center. they'll know for sure. speak to greg. tell him steve sent you there.
__________________ need 17" z wheels in so cal? http://tinyurl.com/zwheelsfs |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
