Old 10-24-2011, 12:57 PM   #1
rb help
have an rb s13 ran clean real good over heated turned it off let it cool down put water4 drove it for a bit and i think the motor locked or something cuz if i try to push start it locs my diff. motor dont crank sounds like it would b da starter wen i turn the key but y would the wheels lock if i try to push start
90greys13 is offline   Reply With Quote
Old 10-24-2011, 01:02 PM   #2
Have you tried to turn the engine over by hand? I would start there and see what you get.
-Aaron
hummer96 is offline   Reply With Quote
Old 10-24-2011, 01:07 PM   #3
ok cool but if the starter is stuck or somethinf theres no way it can hold the engine from craking right
Old 10-24-2011, 01:08 PM   #4
when i push start it
Old 10-24-2011, 01:17 PM   #5
...maybe. If you're worried pull the starter and then throw a wrench on the crank bolt and give it a go. When you say overheated, how hot did it get?
-Aaron
Old 10-24-2011, 01:31 PM   #6
wel it went like three quarters way dude and it had like a knok but for sure n da head i was driving after n it just shut off n me n turned on again then never turned on again but dam idk hope motor aint locked
Old 10-24-2011, 01:35 PM   #7
OBEEWON's Avatar
Sounds like something inside of it broke. You need to pull it apart. Don't do any further damage.
BUT
there is a tech section.
I must be getting old and crotchity...
fantasticvoyagesunlimited.com
Old 10-24-2011, 01:42 PM   #8
but def the head the botom end has like 60k or less
Old 10-24-2011, 02:14 PM   #9
It's kinda hard to tell what you're saying...please toss some punctuation in there. Anyway, if there was a knock I would not have kept driving it but it's too late now. Like I said, try to turn the engine over by hand to see if it does, you feel any resistance spots, etc. If the sound was coming from the top end, you could also pull the valve covers and see if anythings out of place. Gotta turn some wrenches at this point to figure it out.
-Aaron
SEO by vBSEO 3.6.0 PL2
