| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | #1 |
Trader Rating: (0) Feedback Score: 0 reviews | Stereo issues HELP Not sure if this is the right place to ask this, but i am having trouble installing a a stereo in my 92 240sx. The kid i bought it from said he didnt have the deck hooked up because he didnt listen to the radio. So when i went to plug it up it wouldnt turn on. I tested for voltage coming from the stock stereo harness and got tiny readings like .1V or .7V but that was it. So i checked the audio fuse under the steering column and it was fine. I then ran a separate power wire to the deck from a 12V power supply in the fuse box thinking that the power wire was bad, and the deck still wont turn on. I have no idea what to do now, does anyone have any suggestions? Thanks |
| Sponsored Links | |
| | #2 |
| Post Whore! ![]() Join Date: Mar 2008 Location: Stanton, CA
Trader Rating: (81) Feedback Score: 81 reviews | is the harness cut? you need to check these wires with a test light. reb/black - 12V blue - Ignition and nissan doesnt have a ground for radios so you have to ground it to the chassis. you cant just give it power and expect it to turn on.
__________________ http://squarespokes.com/ |
| | #4 |
| Premium Member ![]() Join Date: Apr 2007 Location: Bay Area, CA.
Trader Rating: (18) Feedback Score: 18 reviews | What besTint said is true...240's don't have a ground. That is why even if you ran another source of power you still would'nt get power. The antenna wire acts as a ground in 240's so if you don't have the antenna plugged in to the aftermarket deck it won't work. If not you can just ground the wire to the chassis. |
| | #5 |
Trader Rating: (0) Feedback Score: 0 reviews | i have a separate ground on the chassis. and i bought a brand new deck think that the old deck was bad, and still nothing. are there any other fuses that deal with the audio that i should check? the harness isnt cut. |
| | #7 | |
Trader Rating: (0) Feedback Score: 0 reviews | Quote:
what exactly does a deck need to turn on? is it just power and ground? or do you need a signal wire to? | |
| | #8 |
| Premium Member ![]() | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
