Old 11-06-2009, 11:42 PM   #1
Spring Break '92's Avatar
cold weather hard starts
The temps just dropped pretty drastically in my area. I had let my car sit for a couple of days and it started reluctantly and ran a little rough. I ended up shutting if off and doing a couple of times until it would only crank over. Took the plugs out and let them dry off, put them back in and no problems since. What methods or products do you guys use or do to help out with cold weather starting? Im going to stock up on bottles of fuel antifreeze/water remover in the morning.
White denim and a coke habit.
Spring Break '92 is offline   Reply With Quote
Old 11-06-2009, 11:52 PM   #2
M11's's Avatar
i hate parking my car in the cold it always takes a few cranks to start and forever to warm up
M11's is offline   Reply With Quote
Old 11-07-2009, 12:46 AM   #3
miklos's Avatar
They have heaters for the engine and remote starters and more........
miklos is offline   Reply With Quote
Old 11-07-2009, 12:56 AM   #4
mxexux's Avatar
Its the battery that needs the warming up. Batteries don't like working in the cold. Once heard somebody say that u should pee on it, but I wouldn't do that.
mxexux is offline   Reply With Quote
Old 11-07-2009, 04:07 AM   #5
You guys in So Cal. are lucky. The cold makes everything more difficult.
Old 11-07-2009, 07:55 PM   #6
SR_Vlurs's Avatar
Send a message via Yahoo to SR_Vlurs
where are you at spring?
im in pa so its most likely harder for me then for you
¿$phinx?
SR_Vlurs is offline   Reply With Quote
Old 11-10-2009, 04:20 PM   #7
What kind of engine do you have? If its an sr i had the same problem. I had to sit in my car and crank it for aprox. 5 min until it would start up. Ended up being not enough power going to an ecu wire.
penco is offline   Reply With Quote
Old 11-10-2009, 05:05 PM   #8
clark's Avatar
you guys got fucked up motors.
i have a redtop SR from a 91 silvia probably with like 70-80k miles on it. shit starts up like a champ every time, hot, cold, freezing, hell last winter i had icicles forming on the inside of my windshield and started right away.
you guys need to check your timing. when i first had the motor, it would crank like 5 times, die, then i'd turn it to start again, then it'd start right awy.
adjusted timing, and ever since it starts right up.
clark is offline   Reply With Quote
Old 11-10-2009, 06:01 PM   #9
I have a KA and I live in VA. My timing is on point, nothing wrong with the motor, it was rebuilt about 30K ago. Who knows what the problem was, I'll just chalk it up to the fuel that the local gas stations hasn't changed up to winterized fuel yet and the temp dropped rapidly, its been a non issue for me ever since.
Old 11-15-2009, 09:13 AM   #10
97nismo's Avatar
my D21 had rough starts but my s14 cranks no prob
weird
97nismo is offline   Reply With Quote
Old 11-15-2009, 09:35 AM   #11
I have a winter beater. Best product available.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 11-15-2009, 08:17 PM   #12
SR_Vlurs's Avatar
I have a s14 sr and it always cranks over on the first try I was just saying that winters here are usually nasty
¿$phinx?
Old 11-15-2009, 08:27 PM   #13
my car starts up fine in the cold it is the warming up tht takes a while for me because i live in the mountain area
alliance is offline   Reply With Quote
Old 11-16-2009, 01:37 AM   #14
Frydways's Avatar
when i was living in MT, it would get cold regularly. Below 20 every night and in the morning the SR would take maybe a second or two extra to start, but it would catch. Then occasionally it would idle a bit funky until you either revved it or let it warm up a bit. Honestly though it was never anything I was concerned about. I lived in cold areas for most of my life and every car I ever had shared similar symptoms when it got cold out. If its starting and running I would say you're fine. Throw some HEET in the gas tank along with some injector cleaner and call it a day. That usually helped me out a lot.
Frydways is offline   Reply With Quote
SEO by vBSEO 3.3.0
