Old 10-29-2009, 07:34 PM   #1
minor_times's Avatar
Stuck Coilover
So I've got a stuck perch, the silver threaded part that the rings spin on.
So far I have done
PB blaster..about 3 cans soaked almost daily for the past week and a half
Vinegar
Mallet
Hammer
Torch
Channel Locks
Strap Wrench
I'm not gonna give up but I'm out of ideas..any suggestions?
minor_times is offline   Reply With Quote
Old 10-29-2009, 09:28 PM   #2
Sileighty_85's Avatar
let me guess, this is probably a Megan Coil over huh?
Had a buddy with the same problem, contact the manuf. you'll probably have to send it to them to remove
Or you could cut it off j/k
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 10-29-2009, 09:32 PM   #3
AFC #1
S14DB's Avatar
Aluminum body and Collar?
Comments should be taken as Opinions not as Statements of Fact.
Old 10-29-2009, 09:36 PM   #4
krayzbigmac's Avatar
Send a message via AIM to krayzbigmac
I've had the same problem with an old rsr coilover. Ended up using a pipe wrench, it sorta messed up the collar, but I got it loose.
-Mac
krayzbigmac is online now   Reply With Quote
Old 10-29-2009, 09:40 PM   #5
i got the same problem with my Tein He coilovers. The perches are aluminum and wont budge at all.
marat is offline   Reply With Quote
Old 10-29-2009, 09:54 PM   #6
Yea they are aluminum..I might have to try the pipe wrench since its getting beat to shit anyways lol
Old 10-29-2009, 09:55 PM   #7
ZX88's Avatar
pb blast it. then take a tooth brush all around it then use bfg. i seriously had my coilover set for 2 years rain salt, dirt rust. and it came undone after i thought it was seized using this method.
destruction mode 1
Old 10-29-2009, 09:58 PM   #8
big freakin gun??
Old 10-29-2009, 10:00 PM   #9
can't knock the hustle
racepar1's Avatar
Trader Rating: (37)
Why not just cut it off at this point? It sounds like it's half destroyed anyways. A lot of coilover manufacturers DO sell replacement hardware like perches. I KNOW for a fact that TEIN and JIC do, they're not that expensive either.
Disrespecting $20k + sports cars since 2007
-1989 nissan 240sx: uber track whore
-1994 infiniti Q45t: daily baller
NEED A MECHANIC IN SO-CAL? LOOK HERE:
http://zilvia.net/f/south-western-st...-mechanic.html
Old 10-31-2009, 10:38 PM   #10
i had same problem but i used liquid wrench instead of pbblaster. use a chisel and the biggest hammer you got or go with the pipe wrench that was suggested it works...
nismosx is offline   Reply With Quote
Old 11-01-2009, 06:06 AM   #11
Firestorm's Avatar
Send a message via ICQ to Firestorm
take a hammer and a chisel and go to town on it...worked for me.
letting it soak in pb blaster should help...
Firestorm is offline   Reply With Quote
Old 11-01-2009, 07:42 AM   #12
Put a screw driver in a groove on the collar and hit it with a hammer. Hot water also works for me too.
shanelach is offline   Reply With Quote
Old 11-01-2009, 08:47 AM   #13
MURPHY's Avatar
Send a message via AIM to MURPHY
a hammer/chisel to the collar is gonna fuck it all up. use a big pair of channel locks, a vise and inforce/pb/wd40
wait your in fburg va? haha wtf
MURPHY is offline   Reply With Quote
Old 11-01-2009, 01:57 PM   #14
i used a hammer, and flat head on mine with some wd40, took a minute but it worked, didnt chew the perch up to bad either...
(nismo coilovers)
1995 240sx SE (current)
Ceepo is online now   Reply With Quote
Old 11-01-2009, 05:17 PM   #15
Martino's Avatar
I have the same issues with my 2 front megans. I've soaked them in numerous amounts of things, used giant pipes, huge wrenches, chisel...you name it, I've used it. I've even tried a small amount of heat...NOTHING!
I've contacted megan and they sell the perch for $50 each.
I've yet to figure out getting them off though...
I've also got a deposit on them so I'm just having my sponsor make me custom ones...
Good luck though.
Shake 'N Bake
VisualSugar.com - Media and Design
Martino is offline   Reply With Quote
Old 11-01-2009, 05:56 PM   #16
Matej's Avatar
People, grease up the threads before you install your coilovers, and whenever you have them taken apart. They even sell anti-seize sticks in any parts/hardware store, but regular lithium grease works just fine. You will never have this problem, ever.
ohtheIRONY.biz
Matej is online now   Reply With Quote
Old 11-01-2009, 06:01 PM   #17
Yea the hammer and punch worked on my collars but that wont work on the perch unfortunately.. id put a pipe wrench on it but it would ruin the threads
SEO by vBSEO 3.3.0
