Old 09-09-2009, 10:09 PM   #1
Mista Lee's Avatar
Send a message via AIM to Mista Lee
How to deal with a melted fuse?
So the other week my turn signal decides to shit on me and i attempt to take the fuse out but it took a few tries.
Looks like the fuse melted, now I'm stuck on options on how to take the remainder of the fuse out. Tried using tweezers but that was fail.
aaaaaaaand. another quick question.
So when i bought my car, I never really bothered taking off the silencer, but when I did, I found this..
Does this make a difference in any way?
PbNation.com l NikeSB.org l POTN
Mista Lee is offline   Reply With Quote
Old 09-09-2009, 10:16 PM   #2
Sileighty_85's Avatar
Whats size amp is that fuse and what amp is suppose to be in that slot?
Either that is the wrong amp or somthing is grounding out causing high amp draw and excessive heat
Problem "might" lie before the fuse. Or in the fender well harnesses if your wheels are rubbing though the harness
try using a small screw driver to wedge/chip out the prong?
The exhaust: all your steel wool has poofed out so now your exhaust is louder and makes a rattling noise when you driver around.
Its no big deal if you dont mind the sound, but to fix you need to replace that muffler section
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 09-09-2009, 10:25 PM   #3
Mista Lee's Avatar
fuse amp: 10A
supposed to use: 10A
I'll give it another go with some smaller flat heads.
Old 09-09-2009, 11:30 PM   #4
VIPremium Member
S14_Kouki's Avatar
try with a fine tip niddle nose?? and dont worry about your exhaust
S14_Kouki is offline   Reply With Quote
SEO by vBSEO 3.3.0
