| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | #1 |
| Zilvia Member ![]() | just wondering if an safc2 needs an ecu attached to turn on. i wired it up checked everything even had it double checked. but my ecu isn't in the car. was just wondering if it wont turn on just because the ecu is missing. ecu is not in my possession.
__________________ 2005 Sexually Transmitted Infection |
| Sponsored Links | |
| | #3 |
| 雪彫刻専家 ![]() | If I recall correctly, it does need the ECCS to turn on. The signal it uses to turn on is the MAF signal, which is provided by the ECCS. |
| | #4 | |
| Zilvia Member ![]() | Quote:
__________________ 2005 Sexually Transmitted Infection | |
| | #6 |
| Leaky Injector | If you only want to check if turns on and thats it, you can simply run the power and ground wires. But you won't get any readings without an ecu so it pretty useless, it still dosnt mean it works... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
