| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | #1 |
| Zilvia Junkie ![]() | Kouki tail light sockets I have searched here and all over the net, has anyone found replacement bulb sockets for Kouki tail lights [180sx] RHD japsn parts lists the wrong part as the sockets for the tail lights but if you look at the diagram on there website that is for the center garnish Product Image list I gave them the part # from that diagram and they asked for the skew# which I don't have. Anyone ever find these? Thanks |
| Sponsored Links | |
| | #2 |
| motherfucker mike ![]() | if youre talking about the FACTORY 96-98 180sx tail light sockets that have male connectors which plug into the chassis harness, i should have some of those. I tend to throw them in a box after doing LED conversions. I may not have many, and I know I typically dont keep the reverse light connections.. but let me know which ones you need and I'll try to help mike / clearcorners.com |
| | #3 | |
| Zilvia Junkie ![]() | Quote:
I need the factory brake/running light and the turn signal sockets for both sides I need to know what bulbs came in them also if you have the number I really appreciate your help with this, let me know what you want for them and I'll paypal you Jerry | |
| | #5 |
| Nissanaholic! ![]() | Part Numbers are Socket Assy-RR 26556-60F00 Socket Assy-RR 26551-60F00 You'll need Two of Each one is for the outer light, the other is for the inner light, cannot remeber which is which. You can get the bulbs from autozone
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress |
| | #6 | |
I have the part# for the sockets but can't find them anywhere, I gave those # to RHD japan and they never got back with me In the Nissan diagram I posted above you can see the part # also Thanks again | |
| | #8 | |
| You got me runnin up the walls ![]() | ugh. i hate this. i sold a set of koukis just because i couldnt find the bulb sockets. where were you then ixfxi? lol
__________________ Quote:
| | #10 |
| Post Whore! ![]() | Did you try the dealer? It's an OE number, they can order it through Motorsports.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #12 | |
| motherfucker mike ![]() | Quote:
contact@clearcorners.com | |
| | #13 | |
| | #14 |
| Post Whore! ![]() | Sorry to thread jack, but I have been curious, do the kouki tail connectors plug right into the 89-93 harness, or does the harness or the connectors need to be modded? I have had a couple sets of Ebay eurotails, and they always come with two sets of sockets/connectors, and I have been wondering if the other set is for cars with a harness for kouki tails, because the connectors are different. That brings me to my next point. Has anyone tried if the eurotail sockets fit the kouki tails? Found this picture of the kouki sockets, and they seem to look the same as the eurotail ones. ![]() If they fit, that could be an alternative. Just buy a set of the cheapest eurotails off Ebay, use the sockets/connectors, and resell the eurotails with the other set of sockets.
__________________ ohtheIRONY.biz |
| | #15 | |
| Sponsored Links | |
| | #16 |
| motherfucker mike ![]() | ![]() Just to make sure everyone is on the same page, above is a pic of what the factory connector looks like the J-SPEC 96-98 180SX tail light harness. For the NOOBS, this harness is different than the US-spec 89-94 vehicles. With that said, you need a hybrid connector. The hybrid connector uses the bulb sockets from the J-spec lights mated to the US-spec connector. Once modified, the lights will be plug-and-play. What I will offer you cheap fuckers, is not the US-spec connectors. I will offer the J-spec bulb sockets as they come new when you buy the 180SX tail lights. Its up to you to modify the harnesses and create the special hybrid I refer to above. Now, if you guys are super pussies and/or have fear or working on electrical shiet, let me know and I will take care of all that for you, for an additional cost (of course). Afterall, I am a Jew Bear. note: I am not sure how many connectors I have in my storage, I will need to search. So if you guys e-mail(ed) me, sit tight and wait while I rummage through all this stuff. Please understand that most e-mails with the "240SX" in the title are at the absolute lowest priority in my day-to-day routines, because you guys are like the 1% of customers who assist in paying my bills. Thank you very much 240SX owners. Sincerely yours, Mike @ clearcorners |
| | #17 | |
Stick with the OEM plugs/sockets, stay away from garbage. | |
| | #19 |
| Post Whore! ![]() | Zoom in a little more, it's not blurry enough. Seriously though, anyone can wire these up if you have a brain. The pinout is the same, so it's a matter of just matching wire to wire, soldering, and wrapping up.
| | #20 |
| Zilvia Junkie ![]() | LOL.. I didn't take those pic's I got them from a post on here, and you are right wiring these is not hard , just think a little |
| | #21 |
| Nissanaholic! ![]() | Here ya'll go ***UPDATED PICS*** Here---> S13 Kouki Tail Wire Up THESE ARE OLD PICS FROM WHEN I FIRST WIRED THEM UP, WIRES SINCE THEN HAVE BEEN SOLIDER AND HEAT WRAPPED. BROWN SOCKETS ARE BRAKE LAMPS WHITE SOCKETS ARE TURN SIGNALS Driver Side ![]() OEM Body Harness > Kouki Tail Wires Inner Brake Lamps Driver/Passenger Red/Blue stripe > Green/White stripe Red/Green stripe > Green/Yellow Stripe Black > Black ![]() Driver Side Turn Signal and Outer Brake/Parking Light Red/Blue stripe > Green/White stripe Red/Green stripe > Green/Yellow stripe Green/Black stripe > Solid Green Black > Black Both Turn and parking lamp share same Ground ![]() I think these are right, I got paint on a few wires so hard to tell Passenger Side Outer Brake/Parking Lamp and Turn Signal Red/Blue stripe > Green/White stripe Red/Green stripe > Green/Yellow stripe Green/Yellow stripe > Solid Green Black > Black Turn and Passenger/brake share same ground ![]() ![]()
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress Last edited by Sileighty_85; 09-11-2009 at 05:45 PM. |
| | #23 |
| Post Whore! ![]() | Another question, sorry. Is the new trunk lock cylinder absolutely necessary? I know it has to be in the same location, so I don't see why the stock 89-93 lock wouldn't work unless it is fatter or longer, which I kind of doubt. Or is the lock cylinder just something that Nissan in Japan decided to include with the taillights assuming if someone needs to completely replace their taillights then they might need a new lock as well?
| | #24 | |
| Nissanaholic! ![]() | Quote:
You can put a few washers inbetween the lock and the body to space it out a little more (I did) works fine just add some silicone around it to seal it.
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress | |
| | #26 | |
| You got me runnin up the walls ![]() | fucking little devils im still pissed i sold my lights because is couldnt find them. i also went to the dealer and my dealer was fucking cluless. damn bald ass mofo
| | #29 |
| motherfucker mike ![]() | okay boys................. an update for you all i've gotten quite a few requests over the past month or two from folks who need connectors. no biggie... 1 set, 2 sets, 3 sets, 4 sets, 5 sets, etc........... I'm starting to run low here and dont plan on unloading my entire supply of connectors to you guys, because I still need to have some in stock for when I need them. So just want to make a few things clear here: #1) I'll help you guys out as I can #2) The price I charge for these is minimal #3) Therefor, since you dont pay my bills, I'll get to you guys WHEN I CAN #4) Therefor, dont expect immediate response. #5) These parts are in my storage, I need to take time out of my day to look through them. Now onto the more important part: #1) If I dont have the EXACT OEM sockets, I will provide you with alternate sockets #2) Alternate sockets are SEALED sockets, so they are superior to the OE design which are not sealed #3) If I send you alternate sockets, you will need to notch either the socket or the tail light bulb opening. Notching the socket or tail light is very easy and can be done with a fucking nail clipper or razor, its cake. Last, if you need bulbs let me know and I can sell you bulbs as well. Mike / ClearCorners.Com |
| | #30 |
| Been in this since Jan. 2003 ![]() | CLEARCORNERS.COM nominated for the Lighting of the Year Award 2009 |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
