Old 07-10-2009, 01:14 AM   #1
gauges replace climate control
Hey guys, im thinking of doing the aftermarket guagues were the climate control goes, and moving my climate control elsewhere.
I've searched around here on zilvia and couldn't really land a good post.
Trying to find a place that sells a kit for doing this kind of thing? I'm thinking of getting 3 gauges installed there.
Any help would be greatly appreciated.
Tensor187x is offline   Reply With Quote
Old 07-10-2009, 01:23 AM   #2
95KA-Turbo's Avatar
I made my own piece out of fiberglass.
I don't have a picture right now, but I'll try and remember to post one up tomorrow.
My Blog - knoop.sumospeed.com
95KA-Turbo is offline   Reply With Quote
Old 07-10-2009, 10:28 AM   #3
Try and get some pictures up!
I want to see.
Old 07-10-2009, 11:14 AM   #4
DreamN's Avatar
Trader Rating: (29)
Send a message via AIM to DreamN Send a message via Yahoo to DreamN
it's custom. measure. get material. cut to size. trim holes for drop-in installation of gauges.
Old 07-10-2009, 11:16 AM   #5
clark's Avatar
EDIT: this is only for S13s
i took out the center vent and got a triple 60MM gauge bezel to go in there.
it's a piece of aluminum with 3 holes. i got it off ebay.
keep your climate control at least for heat broseph, but there really is no need for the center vent on our cars.
clark is online now   Reply With Quote
Old 07-10-2009, 11:18 AM   #6
99maxgtr's Avatar
that is only for s13's unless that's what the op has.
Otis@RB-Performance is a scammer don't buy shit from this scumbag
99maxgtr is offline   Reply With Quote
Old 07-10-2009, 11:31 AM   #7
clark's Avatar
ah good call. i always assume people have s13s
edited my post
Old 07-10-2009, 08:00 PM   #8
I'm not quite sure there is a kit for replacing the climate control. I mean you can put a gauge cluster in there but you will most likely need to extend the wiring harness to the climate controller to re-locate elsewhere.
I have a S14 and re-located my climate control into the arm rest.
Maiku240sxS14 is offline   Reply With Quote
Old 07-10-2009, 09:45 PM   #9
How did you extend the cable(s)? Or does the S14 climate control not have cables for the mix door?
1990 240SR - the "Budget Baller"
Rittmeister is offline   Reply With Quote
Old 07-10-2009, 10:03 PM   #10
ZilviaKid's Avatar
just run more wire?
93 240sx - Coupe - Ka
89 240sx - Hatch - Sr
ZilviaKid is offline   Reply With Quote
Old 07-10-2009, 10:12 PM   #11
Yes that's my real name
Andrew Bohan's Avatar
Send a message via AIM to Andrew Bohan
can't run more wire to make mechanical cables longer
Old 07-10-2009, 10:40 PM   #12
In time-out for misbehaving.
BustedS13's Avatar
stop trying to be mister fancy and cram three gauges in your unused DIN space.
Old 07-11-2009, 02:05 AM   #13
No you have to extended the wire harness (meaning add more wire to each wire), if I recall there are about 32 wire that need to be extended.
You still have to cut the actual DIN to get gauges in there. Plus I was eventually going to delete the radio and put more gauges or switches.
Old 07-11-2009, 02:51 AM   #14
JohnC's Avatar
my solution
and CC goes into the din slot, just need a dremel to enlarge the din slightly.
JohnC is offline   Reply With Quote
Old 07-11-2009, 02:42 PM   #15
BustedS13's Avatar
no you don't. i had two gauges in mine, and you can fit three.
Old 07-11-2009, 10:31 PM   #16
Get ya popcorn ready
timlush's Avatar
Send a message via AIM to timlush
S14 is all electric. There is no mechanical cable.
timlush is offline   Reply With Quote
Old 07-11-2009, 10:32 PM   #17
Kouki_Love's Avatar
Originally Posted by JohnC View Post
my solution
do you have any pics of it on the car?? looks good!!!
Kouki_Love is offline   Reply With Quote
Old 07-11-2009, 10:50 PM   #18
99maxgtr's Avatar
i want one. put me on the list.
thanks.
Old 07-12-2009, 10:50 AM   #19
JohnC's Avatar
will snap a few tomorrow.
Old 07-14-2009, 05:02 AM   #20
JohnC's Avatar
Bad Picture but you get the idea,
SEO by vBSEO 3.3.0
