| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | #1 |
| Zilvia Member ![]() | Exhaust really raspy at high RPM Hey, I have a custom 3in catback with a Tanabe Hyper Medallion muffler on my ka24de and above 3k rpm the exhaust is really raspy and sounds pretty bad. My stock exhaust did this too. I'm positive my cat has shit the bed but do you think that is what's causing the sound? Also, there's a rattling sound above 3k as well. Coming from underneath the car. What could that be?
__________________ '91 Hatch - Work in Progress |
| Sponsored Links | |
| | #2 |
| Zilvia FREAK! ![]() | try 2.5" YouTube - 240sx 2.5" Megan Racing Exhaust rattling sound could be a hanger, did u look under the car while it's on? maybe you have a leak somewhere?
__________________ -robo |
| | #3 |
| Zilvia FREAK! ![]() | Rattlen could be a hanger, heat shield or many other things. It could be raspy for many diffrent reassons as well. 1. How was it bent? Was it scrushed or mandrel bent? 2. How and where does the catback bend? If it was ran just like the factory exhaust then thats your problem. Look at most aftermarket catbacks, they have as minimum bends as possible.
__________________ 92 vert converted 5speed and other little things |
| | #5 |
| Zilvia Member ![]() | the sound and "raspiness" is ALL in the shape and resonation of the exhaust. removing cap could hlep, tyr taking out your cat and putting in a oval shaped resonator.
__________________ Left hand drive 240sx's ARE NOT SILVIAS. |
| | #6 |
| Zilvia Member ![]() | Yeah, it's press bent and is run exactly like the stock exhaust. It was $45 so I'm not really complaining right now. But does the fact that the stock exhaust was really raspy as well mean that something else may be causing the sound?
| | #7 |
| Zilvia Junkie ![]() | It could be the construction of your 3" inch piping. If you had custom piping made, and welded on a universal muffler, then your exhaust would sound raspy if the airflow isnt smooth. That's why so many Japanese companies charge more for exhausts. They actually engineer and test their exhaust for airflow and sound quality. If your raspiness was always there, check your exhaust manifold as well as your cat/downpipe.
__________________ d-maxusa.blogspot.com |
| | #8 |
| Zilvia Junkie ![]() | ^agree-gree^ check your downpipe. Also, make sure there are no gaps where flange meets flange, mine wasnt tight once and sounded like shit allll day until i found the prob, gl
__________________ |
| | #9 |
| Leaky Injector | I had a washer moving around one time on my exhaust and made the whole thing sound like shit. It's probably something small. Get the car on a lift or get under some how and kinda shake things around. If not its your cat.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
