Old 07-23-2008, 01:50 PM   #1
Banned from the Marketplace
do you guys think this would fix my....
do u guys think this will fix my camber problem?
http://www.courtesyparts.com/Merchan...uct_Code=81250
jyb116 is offline   Reply With Quote
Old 07-23-2008, 01:53 PM   #2
and what problem would u have , how bout a pic , we dont know what your problem is ,
zaquanh is offline   Reply With Quote
Old 07-23-2008, 01:53 PM   #3
s13silady's Avatar
well it helps to state what camber problems you are having...
s13silady is offline   Reply With Quote
Old 07-23-2008, 01:55 PM   #4
Administrator
ThatGuy's Avatar
www.SPLParts.com
YES, I had a 240sx. NO, it didn't have an SR. NO, I didn't drift.
Old 07-23-2008, 01:58 PM   #5
well its my right front camber thats out... -1.69 and it suppose to be in -1.50 to 0.00
Old 07-23-2008, 02:02 PM   #6
silnismo's Avatar
what suspension setup are running? and how low are you going to go?
You can't be just like "Oh i have a camber problem, help me out" and expect that we know what your talk'in about.
silnismo is offline   Reply With Quote
Old 07-23-2008, 02:04 PM   #7
well as of right now i am running lowering springs i am trying to get my car past saftey and they wont pass it with the camber like that but after saftey is done i will be throwing back my coilovers which add about a 2inch drop
Old 07-23-2008, 02:09 PM   #8
Administrator
ThatGuy's Avatar
Then do it right and go to SPL Parts like I said and buy the arms to set your suspension up correctly.
Old 07-23-2008, 02:16 PM   #9
projectRDM's Avatar
-1.69 is nothing. Most cars run at least that much, generally more on track, I don't see why it's a safety issue.
FORMERLY R240NA
Old 07-23-2008, 02:19 PM   #10
ya well i dont eather, but what do u do like i just want it to be safteyed like its just a hassle buyin permits days i wanna drive it. so thats why i am just lookin for a cheap quick fix for now thats why i wanted to know if these things would work
Old 07-23-2008, 02:20 PM   #11
aznpoopy's Avatar
you know you can elongate the top hole on the shock mounting bracket and achieve the same exact effect
or install coilovers and raise it to stock height
or use stock springs
or possibly put the camber plate from the coilover on the lowering spring set up
but yes the camber bolt will work
aznpoopy is offline   Reply With Quote
Old 07-23-2008, 02:21 PM   #12
I hate your "missile"
racepar1's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
You can adjust that out by either loosening up the bolts that hold the knuckle to the strut and prying it to give you more positive camber, or loosen the upper mount nuts and pry the top hat over just a bit. That difference in camber is absolutely nothing.
"He's one of those "drift" guys, that's like ballroom dancing to me." -Paul Tracy
Need a mechanic in so-cal? PM me!
Old 07-23-2008, 02:22 PM   #13
well my coils are short and raised to the max so thats why i didnt do that, i am running lowering springs couldnt find stock springs, like i just will go with the camber bolts for now
Old 07-23-2008, 02:29 PM   #14
does anyone else know were to get these closer to canda?
Old 07-23-2008, 03:04 PM   #15
projectRDM's Avatar
I don't know what all that chicken scratch is you just wrote, but are you saying you can't drive the car legally like it is?
FORMERLY R240NA
Old 07-23-2008, 03:30 PM   #16
Dousan_PG's Avatar
serious
1.7 vs 1.5
u cant even see that kind of difference just looking
get serious.
Aaron
Pink GodziRa
Old 07-23-2008, 04:22 PM   #17
hah yes that is correct
Old 07-23-2008, 04:40 PM   #18
JVD
WTF? Take it to a diff shop to get OOP'd. Seriously.
My car passed... and the frame rails were like 2.5" off the ground. Had like 3.something degrees of rear camber.
JVD is offline   Reply With Quote
Old 07-23-2008, 05:15 PM   #19
spool_sample's Avatar
That makes absolutely no sense.
It's common for cars to have .1 or .2 degrees difference from side to side.
I don't see what the problem is.
spool_sample is offline   Reply With Quote
Old 07-24-2008, 09:34 AM   #20
SoSideways's Avatar
The problem is that he lives in Canada, and some Canuck shop is apparently retarded.
JVD is also Canadian, so listen to that man.
Old 07-24-2008, 05:51 PM   #21
honeybadger's Avatar
Thats not really a problem at all...
honeybadger is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
