Old 06-02-2008, 12:53 PM   #1
Godspeed type rs coilover install/review
Didnt know wether to put this in tech talk or here If so mods it needs to be removed feel free to do so. *ahem* Well I got my coilovers last week well i had them for a while just never put them on so now it was sunday after the omgwtfbbq bash (which was cool for those who missed out. Thanks again teddy for throwing such a cool event!), Vrt and friends preloaded the coilovers at 2:30am(yeah were all night owls) in the morning getting ready to install after jacking the car up to find out I didnt have the lock key. The original owner (located in palmdale) had it. Sooo that early cold ass morning came to an end resulting on sunday to go to a shop and have them take them off.
I say this is a checklist of things youll need.
Impact gun
hammer
wrench set
An extra hand if you can get one
A jack with 2 jack stands.
Ipod with some cool music (Buckshot, murs, dilated peoples, with a touch of armin van buuren lol)
est time=hmm depends how quick you are i started at 4 finished around 7
Well about several trips to pepboys i was officially ready to do the install.
One thing Tuan (from aspec) had told me about was the bottom of the camber plate bolts needed to be tighten or else they will fall off and thats a no bueno. Relook over everything before installing make sure all the bolts are tight and etc. Picture below.
1.Before jacking up the car remove all of your lug nuts. Makes things alot easier. I started with the fronts first.
2.Take off the top shock bolts first! I bold this out because you will see why later. Silly mistake on my behalf cause i didnt look.
3.Your shocks are bolted with 2 17mm bolts place the jack under the control arm so when you unbolt the 2 17mm bolts it wont go flying down. youll also want to hold the rotor as well due to releasing the bolts once again.
Picture of where i placed the jack.
Pictures of the of the 2 bolts im talking about.
Now when it came to putting these on i did run into a little problem the coilovers didnt want to slide into the spindle making it a problem It could be 2 things. The coilovers just need to be tweaked a bit or because my fronts have 180sx brake assembly. Either way these bitches were going on so i took the jack and lifted up the spindel to match the coilover itself and hammered it into the coilover slightly because of its tight fit. Pictures listed showing how it doesent bolt up.
They went in with ease after. make sure your pillow mount is facing the right direction(horizontal not sure what horizontal is? look at the picture.) as well. Before bringing it up to the shock towers.
Using the jack this should help you if your muscles arent strong. You dont need to remove the jack to load it up since its already at the bottom. Seeeee easy! Repeat these same steps on the other side. Member AGAIN Take the 3 bolts off the shock tower before taking the bolts off from the bottom shock! Or this will happen.
Notice how the shock is down there and the top remains up there? Yeah not fun. But never fear the cutter is here!
taaaaaadaaaa! Done!
Repeat the step once again to reinstall.
Up next were the rears. Take the wheels off. There are three bolts your gonna take off, but AGAIN take the top shock tower bolts located in the trunk off first!!! Place the jack below by the shock. For this step(installing coilovers) this requires a 19mm, 17mm, and i wanna say 18mm ratchet as well.
Next your going to take off the bolt thats connected to the shock itself at the bottom.
Then take off the traction rods bolt
you will need to use your arm power for this one if you have aftermarket rods. Get a extension, size ratchet and a wrench on one side so you can unloosen the bolt.
Go underneath the ruca picture below.
From there slightly corner the shock and wiggle it around and itll come out with the 3 bolts i told you to take off below freeing it with ease.
Then take your new coilover slide it through
Using the same process to bring up the new shock using the jack do this as well you may need to twist the plate to evenly match the coilover top bolts to the shock tower. after that repeat the same steps for the right and your done!
Note i wouldn't adjust the dampening yet till about 100 miles to break in the coilovers. Again make sure you tighten all the bolts double check all your work and you should be good to go. But not me my next thing was doing this...
yes! Its already installed and ill write a review on that as well Basically i didn't finish my car till 1:26 in the morning. After setting the horn off for a solid 10 seconds knowing i woke up my kids and neighbors i snuck into the house and turned off the lights leaving tools and all outside. G/f goes what the fuck was that? I responded Some guy driving down the street with a bull horn out the window......yeah i know. lol.
Ill write a review later once i tested it out some more i notice some things and whatnot but we haven't tracked these yet. but i need to go pick up my new wheels first. lol. Im sure ill get questions so send me your pms and ill try to help.
Ohh the before and after photos...
Before
Now. yea only one photo at the moment. give me a break i was tired bitches! lol
Thanks again to tuan and the squidd for the preloading.
*vrt.squidd.org*//bobablogn.blogspot.com//
"Love is god, hatin is satin!"
Bobafreak is offline
Old 06-02-2008, 01:08 PM   #2
stiizy's Avatar
Nice as always boba!!
stiizy is offline
Old 06-02-2008, 01:23 PM   #3
BoostedCoupe's Avatar
Location: what I make up will fuck up your skinI pick the buck up and buck buck and buck buck again I will butt fuck your friend then suck up her twin I put the buck up to him then buck buck and buck buck and buck buck again suck nut you duck fuck
nice i cant wait for the review. Does anyone know if they make these for a s14 or not? also you do not have to remove the traction bars if you dont want to. i didnt remove mine when i installed my coils. it just takes more time getting the shocks out with them still on. Anyways + rep to you.
92 vert converted 5speed and other little things
BoostedCoupe is offline
Old 06-02-2008, 01:32 PM   #4
Location: BayArea,CA Concord /Antioch / Pittsburg /Oakland
Send a message via AIM to projekt_s13
Why did you unbolt the extra stuff in the rear? I have installed coilovers many times and i have never had to bolt those.
Originally Posted by DUFFM4N View Post
i smashed that shit like baby asprin....
For Sale:
NOR-CAL (4) Used 18" Falken tires *CHEAP*
projekt_s13 is offline
Old 06-02-2008, 01:51 PM   #5
loserfrancis's Avatar
hey cg how come the traction rod had to be disconnected?
vrt
loserfrancis is offline
Old 06-02-2008, 02:22 PM   #6
I removed the other stuff to take the shock out. It seemed easier that way. i believe it was the stock shock in my way and it was hitting one of the rods so i did that. Time consuming hmm maybe by hand but i had a ratchet gun. >_<
Old 06-02-2008, 02:28 PM   #7
im curious to see how they ride..they are so damn cheap
HS13KLS is offline
Old 06-02-2008, 02:42 PM   #8
da1ndonly's Avatar
+1 i was just about to pm you about the ones thatt i got off of you for mine but question answered thanks.
da1ndonly is offline
Old 06-02-2008, 02:50 PM   #9
ahhh yeee boiii. lookin good now.
ps: no problem on the pre load. also those allen bolts you might want to use lock tight, so they wont find a way to come out.
Tuan234 is offline
Old 06-02-2008, 03:30 PM   #10
fo sho. wheels are next though wooooooooooo! Its like a birthday today.
Old 06-02-2008, 03:35 PM   #11
240srhatch's Avatar
u dont got any more godspeeds do you?? my paypal was having a lil problem but its straight now.. let me know when you can get me a set
240srhatch is offline
Old 06-02-2008, 03:36 PM   #12
yeah man tell us how they ride.
ZenkiKid is offline
Old 06-02-2008, 03:38 PM   #13
MikeisNissan's Avatar
Send a message via AIM to MikeisNissan Send a message via Yahoo to MikeisNissan
Jorge you can buy em off ebay for dirt cheap.
SAVE THE PLANET
KILL YOURSELF
MikeisNissan is offline
Old 06-02-2008, 03:40 PM   #14
240srhatch's Avatar
this guy sells them for cheaper.. he was selling them for $525 plus shipping
Old 06-02-2008, 03:55 PM   #15
da1ndonly's Avatar
ebay price is about $600 + $70 shipping
Bobafreak $525 + $70
bought some off him fast shipment from him
Old 06-02-2008, 04:32 PM   #16
aloe calpico makes me pee
DUFFM4N's Avatar
Trader Rating: (28)
good shit son
CLICK HERE FOR MY BLOG
DUFFM4N is offline
Old 06-02-2008, 08:26 PM   #17
Ezel verkrachtende schijteter
!Zar!'s Avatar
Send a message via AIM to !Zar!
Woah
Woah.
Woah.
Bro. Wtf are you disassembling the WHOLE shock? There is no need.
And WTF are you cutting shit?!
Woah.
-=Mel=-
!Zar! is online now
Old 06-02-2008, 09:35 PM   #18
sergey911's Avatar
hey bobafreak, I got the same coilovers and havent put them on yet. you say it takes 100 miles to break them in and not to adjust the damping. which way do I turn it to set it back to normal Left or Right???
nismo
sergey911 is offline
Old 06-02-2008, 11:04 PM   #19
!Zar!'s Avatar
Normally people set the coils on full soft and roll around for a handful of miles.
Screw it all the way in, "full stiff". Then count out however many turns adjustable your coils are; ie 16 out if they are 16 way, 32 out if they are 32 way adjustable and ect.
-=Mel=-
!Zar! is online now
Old 06-03-2008, 01:58 AM   #20
sergey911's Avatar
lol ya screw it, thanks for the write up tho bobafreak
nismo
Old 06-03-2008, 02:12 AM   #21
Send a message via AIM to uthemofo
yea....you fucked up, haha taking off HELLA unneeded shit, and cutting, hmmm think twice before doing that again. hahah live and learn i guess.
My Feedback
uthemofo is offline
Old 06-03-2008, 02:43 AM   #22
foreverdark's Avatar
So far I have had mine installed for about a week. I actully like how they ride. They're are pretty stiff and drop alot which i haven't done yet cause I need to roll my fenders. But so far good stuff. I'll be drifting with them at Balcony this Saturday and will let you guys know how they hold up.
foreverdark is online now
Old 06-03-2008, 10:26 AM   #23
Neejay's Avatar
lol @ sneeking to install stuff.
subscribed. lol
Neejay is offline
Old 06-04-2008, 03:33 PM   #24
Send a message via AIM to KA24DESOneThree
Waiting on a review for these coilovers on small, skinny all-seasons by a driver whose car had blown stock-looking suspension on it previously.
We will all gain greatly from a review. My God, I can't even IMAGINE the change!
Your copycat car reflects your copycat life.
Banned- Calguns.net 1/4/09
KA24DESOneThree is offline
Old 06-04-2008, 03:46 PM   #25
Neejay's Avatar
LOOOOOOOOL...oh wow.
Neejay is offline
Old 06-04-2008, 03:52 PM   #26
ZX88's Avatar
so cheap im optimistic for them but i doubt they last very long with moderate track use. Id definitiy rock these on a daily though.
ZX88 is offline
Old 06-04-2008, 03:53 PM   #27
the fuck. and who the fuck are you? ohhh no one.....thats right. Its a review/write up btw shocks werent blown. wow people these days make a write up you get negativity as if they contributed something. GTFO chump. yea guys im rockin all seasons......
wow did it get hot in here....
Old 06-04-2008, 04:05 PM   #28
ZX88's Avatar
hells yeah^
ZX88 is offline
Old 06-04-2008, 04:09 PM   #29
luftrofl's Avatar
Originally Posted by Bobafreak View Post
the fuck. and who the fuck are you? ohhh no one.....thats right. Its a review btw shocks werent blown. wow people these days make a write up you get negativity as if they contributed something. GTFO. yea guys im rockin all seasons.....
Chill, seriously.
I think that KA24DESOneThree has a valid point. The OP said that a review would be posted. As is often the case, the new coilovers may be compared to what was previously on the car- stock, probably worn shocks with worn upper mounts. That really doesn't seem like a good way to review a product to me.
On the other hand, I could be wrong. The OP could go take the new stuff to a shock dyno, then to the track, and report on wear and tear.
Engrish is funny in Japan. In America, it's for stupid fanboys.
luftrofl is offline
Old 06-04-2008, 04:10 PM   #30
My Gasoline Always Surpreme
los_inc's Avatar
Send a message via AIM to los_inc
you sexy beast! -los
reviews
los_inc is offline
SEO by vBSEO 3.3.0
