| Chat General Discussion About The Nissan 240SX and Nissan Z Cars |
| | LinkBack (4) | Thread Tools | Display Modes |
| Zilvia Junkie ![]() | Fitting S15 cluster in a S13 dash Ok so i got the cluster working fine in the car... now to make it FIT in the car. First i took the dash out and striped it, it was all cracked up anyway ![]() Then i lined up and notched the dash so the cluster would fit ![]() ![]() ![]() Then i chopped up the bracket that is screwed to the underside of the dash that used to hold everything together ![]() ![]() Then i trimed them and glued them in place, notice how the top is slightly angeled. the new bottom mount hole centers line up with the bottom edge of the old mount points and the little nub for the vents ![]() ![]() ![]() ![]() Im using 3M 8005 for the glue, stuff is solid as a rock and hard to get ahold of but should never come off... and you SHOULD let it cure for 24 hours. Stay tuned for the rest when i glass over everything and fix up the bezel |
| Sponsored Links | |
| | #6 | |
| Zilvia Junkie ![]() | Quote:
BEfore ![]() After: ![]() | |
| | #8 |
| Zilvia Junkie ![]() | yes i will glass it and paint it. thats the only easy way to smooth out all the curves and make the guage pod look stockish. the covering and all the foam make it look much smoother than it really is. jdm look... not so much. thats not my reason for doing this at least. i was kinda pissed that i can peg the speedo in 4th, i wanted a speedo that can tell me how fast im going all the time, plus i like the center tach... and it doesnt make the car seem so damn old. for the bezel, it shouldnt be to hard to fit, i trimed the top edge of the dash a little to get some extra clearance, cut a straigh line through the top of the bezle. now im gonna spred it there about and inch or so and add a spot to secure it with the same screw holding the cluster top in. fill a little on the sides and bottom... trim the top back half off (s15 cluster is wide at the top not bottom) and it should go in fine. |
| | #10 |
| Leaky Injector | Can't wait to see how this turns out. My friend and I finished putting everything together on the breadboard (with help from your sig converter thread) a couple months ago and havnt gotten back to it since (still gotta figure out the wiring). Keep up the good work and keep showing us progress. |
| | #11 |
| SLINKY + ESCULATOR = Fun Times ![]() | You might wanna put some clear coat on that dash. With the sun beating on that dash constant, that black will turn doo doo brown color in a couple of months.
__________________ |
| | #12 |
| Zilvia FREAK! ![]() | ^^^ hahaha true that.. do that asap... but try not to make it all shiny, itll look all tacky. lol. btw this is pretty cool... never thot of anyone ever doing this.. good job! ps-yay for 1000th post!
__________________ thurs. knights. |
| | #13 |
| Zilvia Junkie ![]() | Im so tired of every thread being a question abouot how to do something... people should just start trying new stuff to see how it works out, then post it up for others For the paint, i dont think im gonna rattle can it, i have a spary gun so i can use auto paint, more flex and shouldnt fade ZooMxxl, PM me if you need help with the wiring |
| | #15 |
| Zilvia Junkie ![]() | You are.... being able to convert it in your head instantly. Quite easy.
__________________ My opinion gives me redboxes |
| Sponsored Links | |
| | #19 |
| Leaky Injector | |
| | #20 |
| Zilvia Junkie ![]() | Ok here is the start of the bezel ![]() I cut a slit at the top and shaved most of the back ![]() see how much room the foam and cover used to take up ![]() Im using a piece from the bracket i cut up earlier for the top mount part. bent the top parts up and tirim them back to get it to fit in right ![]() ![]() then tape it and use random stuff to hold everything still so the glue can dry ![]() |
| | #23 | |
| Zilvia FREAK! ![]() | Quote:
good shit, keep it up
__________________ | |
| | #25 |
| Leaky Injector | [ZooMxxl, PM me if you need help with the wiring[/quote] I will keep you in mind if I have any questions when I get back to the project again. Once more, thanks for the help and great postings. |
| | #26 |
| Zilvia Junkie ![]() | POWER and PROPS to you, because thats one hell of an undertaking but well worth it because the S15 cluster is not only purty but so much more readable and the big tachometer is much more driver oriented. |
| | #27 |
| Zilvia Junkie ![]() | Crap its been a long time. Work has really been keeping me busy and ive had to spend time on a few other projects, like fixing my roommates Camaro SS, He put his tranny valve body together wrong and fried 3rd. Lucky he didnt blow up anything else. Ive also been working on redoing my E-Gay headlights, i like the look, they just have a bad implementation. So im redoing it with a SS frame and some hella 90mm projectors. Ill update my other thread on those when im get some more progress done. The worst thing is i have to replace my steering rack this weekend. Ill put up a howto and all when i do it. I got it from the rack doctor for like 109 plus an 85 core. It has a 2 year warranty so ill put a small review about it too. Anyway here is my update... I put down 2 layers of glass mate and resin to smooth out the molding marks and mold in the guage pod. Then sanded it kinda smooth with 80 grit and a DA. Now im putting down a few coats of poly glaze to smooth it all out before i paint. Oh i also epoxied all the vents in place. I did this mainly because they would crack or break if you look at them funny. seriously the top vent was like in 6 pieces. I know there are 2 or 3 bolt holes under then so ill just drill the hole back out when im done and find some rubber plug to fill it when im done. If anyone has any idea how to keep old plastic from cracking and breaking, im all ears. ![]() ![]() ![]() ![]() |
| | #29 |
| RedLine SlideWays ![]() | looks clean man keep up the great work
__________________ ![]() Team RedLine SlideWays www.aigraphix.com/wordpress Just another rough day at the office. |
| | #30 |
| Pink GodziRa ![]() | not crazy about the zit on the top of your dash! but im looking forward to the final product!! |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/chat/180687-fitting-s15-cluster-s13-dash.html | ||||
| Posted By | For | Type | Date | Hits |
| Hardtuned.net > S15 Dash Setups......... | This thread | Refback | 06-19-2009 11:00 AM | 9 |
| Nissansilvia.com.au -> S15 Dash Setups......... - Hardtuned.net | This thread | Refback | 06-11-2009 06:50 PM | 1 |
| Hardtuned.net -> S15 Dash Setups......... - Hardtuned.net | This thread | Refback | 06-04-2009 03:36 AM | 1 |
| Nissansilvia.com -> S15 Dash Setups......... - Hardtuned.net | This thread | Refback | 06-04-2009 03:08 AM | 19 |
