| | #1 |
| Premium Member ![]() Join Date: Jul 2005 Location: Riverside, SoCal
Trader Rating: (288) Feedback Score: 288 reviews | /MODE PLEASE LOCK THREAD. DATES BACK TO 08/2012 Testing Waters Testing Waters Testing Waters Testing Waters SERIOUS BUYERS ONLY! PLEASE CONTACT ME ONLY IF YOU HAVE CASH IN HAND 1989 Nissan 240sx Hatch Power Windows,Locks,Mirrors Cons -Salvage Title(Was told for theft back when it was stock years ago). I would not go this far into a car that I didn't believe was straight. If there is a serious buyer, I am willing to take it to a frame shop to show proof this car is straight without damage. -Needs new blower resistor(JDM resistor one is no good, blows heat in full blast). I will replace before I have a buyer -Needs an alignment. I will get one before I have a buyer. -This car is VERY solid and reliable,runs real cool, handles great, makes no weird noises and is built with Daily/Track in mind. The exhaust is not loud, interior doesn't rattle like most 240's, A/C is possible if you really wanted it. Reason for trading, or selling is because I drive this 1 or 2 times a week and it returns to the garage. I have a brand new car so I use this for fun. Trades:Offer me something of equal value, I REALLY want cash. I WILL NOT trade and add cash. I am hoping to sell but I AM IN NO RUSH, if it doesn't sell, I will continue to build it. Price: Reasonable offers! None of that B.S. saying "Oh its salvaged" because the frame is very straight and a CLEAN TITLE doesn't always mean its legit(you don't have to go through insurance or even dmv if you crashed/got hit and someone took off,etc) Now onto the car. There are probably a few things I'm forgetting as well. All said NEW parts have under 5k Miles on them. Engine/Performance: S13 SR20det Red Top Only ran Mobil 1Full Synthetic 10w30 Mildly tucked Harness Brand New CAS Brand New TPS Brand New IACV Brand New Fan Shroud Brand New Gates Micro V Belts Brand New Black Silicone Hoses Brand New Coolant Overflow Tank Brand New OEM timing Chain Tensioner Brand New S14 SR Water pump Brand New Walbro 255lph Fuel Pump Brand New Fuel Filter Greddy 52mm Black Electric Oil Pressure Gauge Greddy 52mm Black Electric Water Temp Gauge Greddy 52mm Black Electric Boost Gauge Greddy 2 Row Radiator(Runs 158F all day) Nismo Thermostat Nismo Type-A FPR w/ Marshall Liquid filled gauge and new fuel lines S13.4 Hybrid Valve Cover done by Bardabe Performance All New 7 layer S15 Exh. Manifold gaskets and turbo gaskets New S15 Spec-R Garrett T28 *HKS Step 1 264 Cams-Just installed 09/09/12 HKS Wastegate Actuator Earls SS Oil and Coolant lines ARC BOV Greddy FMIC Nismo 740cc Injectors N62 Maf OEM Mazda Miata Battery RS-Enthalpy Tuned Ecu(740cc,T28, 14 psi) Apex'i Filter Tomei Intake Adapter Powered By Max Flex Cobra Downpipe Catco 3" high flow cat Kakimoto Cat Back(cut and welded to sit higher) Circuit Sport Poly Exhaust Bushings 14lb Flywheel DIF SS Fire Sleeved Clutch line(Not installed) 6 Puck Clutch PBM Magnetic drain plug Circuit Sport short Shifter Suspension/Brakes: Powered By Max Coilovers Nismo 2 way LSD JDM Diff w/ 5 bolt axels and diff cover New Outer CV boots SPL Version 1 Toe Rod's SPL Version 1 Traction Rod's Kazama RUCA's Circuit Sport Tension Rods Johnny Fraz Tension Rod Brace(Like Nismo Brace) Tein Inner Tie Rod's Tein Outer Tie Rod's SPL outer Tie Rod ends(Awaiting S14 inners to install, and I will remove Tein set up) Energy Suspension outer tie rod boots Energy Suspension Front Sway bar bushings/endlinks Energy Suspension rack & pinion bushings Z32 Rear 5 Lug Hubs Aftermarket 5 Lug Front hubs Z32 30mm Front Calipers w/ss lines & slotted rotors Z32 Rear Brakes with working Ebrake w/ ss lines, new pads & slotted rotors Project Mu ebrake shoes Brand new Z32 1” BMC Brand New Duran 215/40/17 tires Brand New Falken Ziex ZE-512 225/40/18 Work Emotion Cr kai 17x9 +17 & 18x9.5 +20 in bright silver Slip on 10mm spacers front Exterior: Fresh Mercedes Black Single Stage Paint(6/12/12) Kouki OEM Bumper(New) Kouki OEM Turn Signals(New) Kouki OEM Position Lights(New) Kouki OEM Extensions(New) Kouki OEM Extension Brackets(New) Kouki OEM Sideskirts Kouki OEM Valences Kouki FPR Center Valence Kouki FPR OEM Style Spoiler Kouki FPR OEM Style Lip (super flexible and strong) Kouki OEM Tail lights Glass H4 Housing Headlights Hella H4 Bulbs M3 Clear Sidemarkers Interior: Full Interior Working Digital Climate Control S14 Manuel Seat Belts New JVC Headunit w/ Aux, USB,etc Pioneer Speakers Clean Black Dash Nardi Classic(kind of beat) Works Bell Hub Newish Turn Signal and Wiper Stalk Nismo Shift Knob New Leather Shift boot F1 Spec Sidemount Seat F1 Spec rails S14 Passenger seat Center Gauge Pod w/ Greddy Gauges All green interior gauge lighting(Cluster,Headunit,Gauges,DCC) DOHC Cluster w/ SR RPM ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________ *Eccentric lockout kit for s-chassis now available. PM Me 180sx Kouki FRP Lips Available 180sx Type X Kouki FRP Rep Sideskirts Available Last edited by Driven08; 05-19-2013 at 01:17 PM.. |
| Sponsored Links | |
| | #2 |
| Leaky Injector | |
| | #3 |
| Premium Member ![]() Join Date: Aug 2005 Location: SoCali 951 Age: 23
Trader Rating: (9) Feedback Score: 9 reviews | Very legit car buyer won't be disapointed Edgar doesn't cut corners sad to see you try and sell it
__________________ ![]() Review Thread RPS CLUTCHES ON SALE! RPS FLYWHEELS ON SALE!! New Products for 2012! |
| | #4 |
| Zilvia Junkie ![]() Join Date: Feb 2010 Location: Orange County, CA Age: 22
Trader Rating: (5) Feedback Score: 5 reviews | Very nice and well built car from what I see, none of that ghetto shit peeps be doing. I would've traded you my vip Y33 if I was still into S chassis. Glws/t! |
| | #11 | |||||
Trader Rating: (288) Feedback Score: 288 reviews | Quote: Quote:
Thanks ![]() PM Sent Quote:
Thanks. Trying to keep it but like I said, if it doesn't sell, I am perfectly fine keeping it. I would like to keep this thread for interested buyers or offers.
__________________ *Eccentric lockout kit for s-chassis now available. PM Me 180sx Kouki FRP Lips Available 180sx Type X Kouki FRP Rep Sideskirts Available | |||||
| | #12 |
| Post Whore! ![]() Join Date: Aug 2009 Location: Moreno Valley
Trader Rating: (46) Feedback Score: 46 reviews | Title is just some bs, excuse for low ballers, one of the cleanest, most well built cars ive been in recently glws or glwt buyer/trader will not be dissapointed! heres some pics i took old but you guys get the idea ![]() ![]() ![]() ![]()
__________________ |
| | #13 |
| Post Whore! ![]() | Freaking beautiful car, wow riverside came up along way! lol. Vouch for the seller, You won't find another car built as clean this side on the westcoast imo. The parts really bring value to the car. A car built on megan racing/godspeed parts would only be worth half the value.
__________________ Keep it classy . |
| | #14 |
| Premium Member ![]() | ![]() |
| | #17 |
| Premium Member ![]() Join Date: Feb 2007 Location: Lake Havasu City Arizona Age: 29
Trader Rating: (9) Feedback Score: 9 reviews | How about a 1993 Fd rx7 ![]()
__________________ “About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html NO FUCKS GIVEN |
| | #18 | ||
I approve this message Quote:
Thanks You have a PM
| | #28 | ||
Thanks. Turns heads all day Airhead. He commented in this thread and his car is also in the Kouki 180sx Pic thread. His car is Clean. My cars twin with different wheels I am willing to SHIP if I get the right price. Thank you I would like a 07+ GSXR 600 but I am focused on getting a house so I need to leave the toys alone for the time being. Thank you. Lots of time, effort and money. PM sent
| | #30 |
Trader Rating: (288) Feedback Score: 288 reviews | I have tried to pm you but your not accepting pm's. Please pm me again with changed settings so we can talk
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
