| | #1 |
Trader Rating: (11) Feedback Score: 11 reviews | clean me out im done 4k obo Selling everything 240!!! Car is in storage in Austin IN. $1700 + transport for car if you cant pick it up. No trades No part out! I can't pay $800 to ship the car here just to chop it up! Parts are located in Pensacola FL, here is the link to the parts I can sell separately pan handle parts Cant take it with me, moving to Germany on the 9th of Jan. fix up my 94 vert, or chop her up for a profit valve train damage from fidanza gears I do have a pro built identical head with 5 angle valve job and stock gears (Ill never have anything fidanza again) ready to go on the car and can ship the head to you for less than I would sell it outright to someone else so long as it goes on the car and this car does not get chopped up! http://www.cardomain.com/ride/589944/1994-nissan-240sx The car- 5 speed swapped sr 20det. suspension- Isis pillowball rucas, front tension and rear traction rods. new oem ball joints, flcas, roll center adjusters and sway bar end links oem rear shocks 3000 miles KYB gr2 front shocks 3000 miles rear tie bar real carbon fiber front strut bar NEW complete 30mm 300zx aluminum brakes including master cylinder, booster, drilled & slotted rotors, and braided conversion lines. 0 miles on rear under 50 on front working 300zx e-brakes with factory 2+2 cables. mc heat shield valvoline synthetic fluid stock sr trans only correct amsoil gl4 fluid used. new clutch master cylinder. ACT /excedy stage 3 street clutch rated for 400ftlbs, under 500 miles lightened chromoly flywheel under 500 miles b&m short throw shifter, shortened and machined Custom Australian Redback knob j30 vlsd diff Engine in car- spare yellow powdercoated valve cover CP 8.5:1 pistons BC pro rods ARP main studs new oem rocker arms new oem timing chain BC valve springs BC titanium retainers BC 272/272 cams Fidanza adj cam gears (what caused my problems) Circuit sport rocker arm stoppers Cometic head gasket ARP head studs 650cc injectors AEM FPR freddy port matched & partially polished intake manifold freddy oil pan oil housing block off 2 oil coolers w/ filter relocation & thermostat. running Ford HP Racing Filter Greddy oil catch can. Recirculated to custom intake pipe. HKS Mega Flow (the big one) intake filter 300zx maf almost new correct heat range iridium plugs unorthodox lightweight pulleys new togue factory braided turbo lines gt2871r .86 around 3000 miles turbo xs cockpit controlled dual stage boost controller. switch next to shifter modified project silvia and cx racing 3.25" ic pipes cx racing 31X11X3 bar & plate fmic. custom ported bumper & core support greddy type s bov altima fans koyo radiator volvo push fan new hoses, sensors and thermostat real carbon fiber air dam modified wiring specialties harness flashed ecu apexi safc 2 black q45 ignitor 3" exhaust wrapped from manifold past test pipe all stainless hardware ss autochrome equal length manifold, divided elbow, barely passes db with silencer installed new gaskets Interior- Ichiban wheel with momo center plate. nitrous capable ractive pedal covers Custom Australian Redback knob autometer carbon fiber gauges: oil press, oil temp, boost, narrow band air/fuel rare factory grey leather seats in need of repair several new nissan switches everything power worked when parked new battery when parked may not recharge after a year in storage clifford motion sensing paging alarm was$650 before install full size battery relocated to trunk with circuit breaker and box head unit, amps, sub box, and big gauge wiring removed!! RCAs for amps and headunit harness in tact lightning 6X9s are still in doors pioneer 6.5s still in rear new trunk lifts hella e-code (ece) headlight conversion near new 225 45 17s front and near new 275 50s (i think its been a while) on rear scuffed icw racing 17X7.5 with spacers to correct offset project car!! engine builder did not know what they were doing fidanza gears were not torqed by assembler and they wrecked my valve train scoring on cams suggests oil restriction to the head parking has taken its toll. needs paint and interior work to look great. needs new top and windshield power top worked but started to leak hydro before i moved and since i couldnt get to her for a year im sure that will need some attention. pics during last build no longer have finished pics, again car is in storage in indiana the laptop that had most recent pics took a dump on me during the move ![]() ![]() ![]() ![]() here you can see the size of the intercooler and the intercooler fan ![]() ![]() this last pic is of the old motor but you can see the carbon strut bar and air dam ![]()
__________________ Buy my car I need it gone by Christmas Eve Last edited by ryanhelton2000; 12-28-2012 at 03:44 PM.. Reason: added pics clicking the link was to hard |
| Sponsored Links | |
| | #2 |
| Touch me, daddy. ![]() Join Date: Jan 2010 Location: 5OH!8 x 9UNO!5 Age: 25
Trader Rating: (20) Feedback Score: 20 reviews | Let me know if you're looking to part a few items.
__________________ ![]() x MEGA $ALE, something for all you JDMTYTE bros. x That means click that link or I beat you up, bro. x |
| | #4 |
Trader Rating: (11) Feedback Score: 11 reviews | Last push for this! Car will be donated unless someone buys in the next couple weeks. Im already giving it away at this price. Might as well see someone I know who needs the work and money take advantage.
__________________ Buy my car I need it gone by Christmas Eve |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
