| | #1 |
| 95 240sx SE 2jz swap TH400 9 seconds 95 Nissan 240SX SE, Pearl white with blue interior. The car was built from ground up by a reputable performance shop that builds high end imports and race cars. It's in extremely clean condition and isn't some hacked up high school project, It's a professionally built Street/Strip s14. ENGINE Real 2jz-GTE Turbo Motor Swap USDM Cams 31x12x3 Huge FMIC Borg Warner S366 ETT Turbo With Race Compressor Cover .92 T/4 Exhaust Supports 900 Hp 3 Inch mandrel Bent Exhaust And Down Pipe TCS Eliminator Kit From HKS Tial 50mm Blow off valve Tial 44mm WasteGate TRANSMISSION Mikes Racing Transmissions Ultimate TH400 With Transbrake Capable of holding over 1200 HP PTC 9.5 Inch Double Anti Balloon Plated TQ Converter B&M Pro Stick Shifter Installed In Factory Location Custom Steel Fully Balanced Drive shaft Deep Sump Low Temp Aluminum Pan Dave H Billet Adapter/Flywheel Setup Big Volume High Capacity Transmission Cooler With Fan REAR END Custom Infiniti Q45 Conversion Custom Q45 Hubs Upgraded With 11/18's Moroso Drive Studs Samson R200 Big Volume Differential Cover 30 Spline 6 bolt R230 Axles Subframe Was Completely Gone Through All New Bushings Made From Polyurethane 3.538:1 Gear Ratio Good For Track And Street Driving Fully Adjustable Chromoly Rear Camber Arms With Heim Joint Ends Fully Adjustable KYB Rear Struts For Drag Racing INTERIOR All Stock Interior Panels Look Like New Full Interior All Seats Intact Very Nice Auto Meter Ultralite Gauges Trans-temp, Oil-pressure, Boost, EGT, Water Temp All Interior Lights/Amenities Work Radio Bezel Is New Has A Kenwood Deck And Sony Speakers FUEL 255 Fuel System For Motor 550cc Injectors Stand-Alone Self Contained Fuel System For Nitrous Aeromotive Regulator, Another 255 pump,Aeromotive Filters For Seperate Fuel Cell Apexi controller NITROUS NX Carbon Fiber Lightning Solenoids - 4 Trunk Feed Line For Nitrous - 4 Teflon Fuel Feed 10lb NOS Brand New Bottle With High Flow Valve With Bracket Bottle Blanket NX Super Shark Nozzle WET SUSPENSION All New Eibach Springs Kyb Adjustable Struts Adjustable Camber Arms New Hubs Front And Rear New Rack And Pinion Brand New Weld 15x 3.5 and 15x8 Pro Stars With New GoodYear 28x9 Slicks MISC Car Runs 10.20's On The Foot Brake @ 136 mph And 9.90s On the Trans Brake with a 15 psi launch. Using an 85 shot and pump gas boost settings @ 19 psi. Boost Can go Much higher, Doesn't have a roll cage and i get kicked out every time. Large Aluminum Radiator With Dual Fans Runs Cool I Have The Grill It's Just Out During Pics Makes 460 Rwhp On Pump Gas 17 Psi Through The Unlocked TH400 No Nitrous Weighs 2800 LBS Has A TransBrake Will Make Full Boost On The Brake. Car Will Work Anywhere Hooks Hard Street Or Track The Car Has Very Good Streetability And Is Very Docile Has 5000k HID System At 20 Psi The Tune Is 11.5:1 Always Runs Starts And Drives Handles And Stops Great Very Quiet Cabin Wise Over 30k Invested Everythings Done Correctly It's a turn key Drag/ Street Car That Always Surprises Domestics, Everything On The Car Was Overbuilt To Handle Hp From The 2JZ engine To The Fully Built Th400 And Rearend. As With All Used Items This Car Is Being Sold As Is With No Warranty Buyers Outside Of USA Are To Pay Any Additional Shipping Charges.The Car Is For Sale Locally And I Reserve The Right To End The Auction At Anytime.Please Email Or Call Anytime With Any Questions Or Offers. Here Is A Couple Video Links To The Car. YouTube - Casper 240 YouTube - casper 240 CALL OR EMAIL ANYTIME 661-233-3069 paxtonautomotive@yahoo.com Last edited by peanut2; 11-09-2009 at 08:00 PM. | |
| Sponsored Links | |
| | #12 |
| Zilvia Addict ![]() Join Date: Nov 2006 Location: what I make up will fuck up your skinI pick the buck up and buck buck and buck buck again I will butt fuck your friend then suck up her twin I put the buck up to him then buck buck and buck buck and buck buck again suck nut you duck fuck Age: 19
Trader Rating: (2) | ahahahahaha a 9second car would kill stock se's if thats what you are thinking. this car would spin se's at 70+ im sure
__________________ 92 vert converted 5speed and other little things |
| | #15 |
| trade for a built evo pm if interested
__________________ 2003 bby evo--->mooded 1992 240sx LS1---> SWAPPED | |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
