Old 11-06-2009, 11:22 AM   #1
RB Rb25det s14 Need it gone
This is a 95 240sx, holds a clean title. Engine is a r34 neo6 running on a Megasquirt 3.0v2 stand alone ecm. Motor is not tuned for current set up for hard driving, but has a base tune, and drives just fine, have taken it on couple road trips and no problems to report. Car is now big single turbo, needs bigger injectors and to get retuned.
Pros:
Ex. Mods:
-Two tone House of Color candy paint with crystal top.
-Smoked head/tail lights
-97 NA supra wheels
In. Mods:
-AEM wide band
-Autometer digital gauges
-EGT
-Boost/VAC
-Oil pressure
-Oil temp
-Fuel pressure
-MegaView digi dash display
-Drift style steering wheel, quick release
-Nismo shift nob
Susp. Mods:
-Tokico shocks and lowering springs.
-Front caster adjustment
-Rear toe adjustment
-5 lug conversion
-R33 brakes conversion
-Stainless brake lines
-Motul brake fluid
PowerTrain Mods:
-MegaSquirt II
-4 bar map sensor
-Megasquirt controled boost controller
-Waste spart with GM coils
-MSD spart plug wires
-R34 Neo6 RB25DET
-R33 RB25DET Trans
-R33 flywheel
-Spec stage 3.5+ clutch
-T3/T4 .70ar/.63ar stage 3
-Turbonetics t3 gasket
-Tomei 1.2 head gasket
-ARP head studs
-HKS timing belt
-HKS timing gears
-Cometic exhaust mani gasket
-Stock header modded for external wastegate
-Synapse 50mm wastegate
-Tial 50mm bov
-3" exhaust
-Jun style intake mani
-Q45 Throttle Body
-Pallnet Top feed Fuel rail conversion
-440cc injects (needs bigger)
-All fuel, oil, vac lines Steel braid lines, A.N. fittings, Earls
-Mckinney motor mounts
-Mckinney solid drift bushings
-Custom drive shaft
-2 way lsd
Prob missing something
Cons:
-Not everyones ideal look..
-Paint is not perfect anymore
-Needs a new starter
-Needs bigger injectors and tuned
-Missing weather strips front and rear window
-No gas gauge
-trans grinds 4th when shift fast
$8500 obo
OLD PICS does not have these wheels anymore, does not have the navi anymore
K20a2ivtec is offline   Reply With Quote
Old 11-08-2009, 02:12 PM   #2
bump......
Old 11-10-2009, 10:12 AM   #3
.....offers?
Old 11-10-2009, 11:47 AM   #4
djstatistics's Avatar
GLWS bro. free bump
djstatistics is online now   Reply With Quote
Old 11-10-2009, 02:02 PM   #5
trade you my bike.
lowso is offline   Reply With Quote
SEO by vBSEO 3.3.0
