Up for sale is a 1995 Nissan 240sx located in Vista, CA. The car came originally as an automatic but was converted to a 5 speed manual. The car has a clean title and has current registration till May 2010. This car is stock, but the timing is off to the point where this car is really not that drivable. Id suggest bringing a trailer or if your good enough bring a timing light and have at it. The problem is that cylinder #4 is misfiring. This car can be driven onto a trailer, so no pushing is necessary. I have the spark plug wires pulled out cause i was checking the plugs but they are back on the car now. Mods on the car are as follows: 5Zigen FNO1R-C rims all around, 17X9 front and 17X10 rear. I do not know the offset. Front tires are Federal 595's, 215/40/R17. Rear tires are Falken Azenis 225/45/ZR17. All tires have pretty good traction left in it. This car had Powered by Max coilovers installed too. In addition to the coilovers it has PBM Rucas and adjustable lateral links. The car is set up for max grip right now. Up front I have a TCS strut bar and a JDM Zenki front bumper. The front bumper is being held on there by zip ties. It also has an aftermarket exhaust. Things this car needs are: new driver side door, unless your good in fixing this. Some jerk hit my car and took off, making a dent on the door and bending the rods that operate the door lever. The window and motor are fine. The only way the door opens is from the inside and doesnt lock. Because of this I took off the door panel, dont worry, of course youll be getting that too. The passenger side door is perfect. Another jerk backed up into the car and took off, so a new hood and fenders are needed. The rear bumper was spray painted by the previous owner with cheap paint, so the heat from the exhaust caused the pain to start peeling off. The brake pads and rotors are new all around, with less than 10 miles on them. The transmission needs a new bush control lever socket. It can be bought here-
BUSH-CONTROL LEVER - 240SX (S14) 1995-1998 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com This part is EASY to install, takes about 5 minutes. The interior has an s13 drivers seat and the passenger one is s14. To whoever buys this car, I will throw in a free set of pulleys and iron 300zx 30mm brakes with the brake master cylinder. I will also give you a timing componet kit in addition to the other items. Also I will be throwing in a Chilton manual for this car. I can be reached by phone or text at 760-415-0033 and my email is
razor3785@yahoo.com Im Dennis btw. THIS CAR WILL NOT BE PARTED OUT. NO TRADES $4000 OBO The price is just starting at $4k. I am more than willing to negotiate the price with you.
