| | LinkBack (1) | Thread Tools | Display Modes |
| 1972 VQ35DE swapped DATSUN 510 Hey guys, it was difficult to reach this decision but I have to sell the Dime. I hope it goes to a good home where all the plans I have left for it will get completed, mainly the bodywork. This is a One-of-a-kind 1972 2-Door Datsun 510 with a VQ35DE Engine Swap. That’s right a 287 hp V6 from a 2006 G35/350z. I have put close to $25,000 into this car, not to mention countless hours working on it. I don’t expect to sell it for that but the closer I can get to that the better of course. I’m going to ask: New price $9,900 obo ![]() This car has the renowned handling & styling of a 510 & the award winning engine of a 350z in a vehicle that is around 1000lbs. lighter than a Z33. This makes for a very fun & responsive streetcar (or race car) that I’m going to miss greatly. Even my wife doesn't want me to sell it which is rare when if comes to my "toys". Engine: VQ35DE from a 2006 G35 (same engine as the 287hp 350z engine) 6 Spd transmission (CD008) Vqswap shifter relocator (moves the shifter 4” forward, where it needs to be) Custom Engine Mount brackets (uses stock rubber mounts, the engine is amazingly completely motionless under load, no twisting) XTD Chromoly lightweight Flywheel OEM clutch & pressure plate Braided Stainless Steel clutch line Modified Intake manifold/Upper plenum to have a larger neck & support a Performance Products 85mm Throttle-body (stock is 70mm) 4” intake piping AEM EMS tuned AAM Angled Plenum Spacer (good for 5-10hp) Rewired with a 240sx fuse box Reversed front crossmember Relocated Battery (behind passenger seat) Fuel System: RCI 15 gallon Fuel Cell Custom Surge Tank Walbro 240lph high pressure pump Mallory 90gph low pressure pump 8AN fuel filters 8AN & 6AN stainless steel braided Fuel lines with Earls, Russel, & Aeroquip fittings Injected Performance Fuel Rails SX adjustable fuel pressure regulator with pressure gauge Cooling: Oil Cooler with Greddy Sandwich Adapter with thermostat Steel Braided 10an oil lines Afco Sirrocco style dual pass aluminum radiator Exhaust: Modified OEM exhaust manifolds (all stainless steel) 2 1/4” stainless piping to 3” aluminized steel pipe 3” resonator & 3” Magnaflow muffler (no catalytic converters) The car sounds great, with the definitive VQ exhaust note Drivetrain: Custom Driveshaft (good for 500 whp) 3.7 ratio R200 Differential with Z32 finned cover & new bearings MadDat R200 conversion Mustache bar OBX Helical LSD (the LSD design faults & weaknesses have been fixed) Shortened Z31 Turbo CV axles (also very strong) Modern Motorpsorts Billet Companion Flanges 280z Stub Axles (known for strength) new bearings as well Interior: F1-spec Mugen Style Fiberglass seats Custom carbon fiber dash with Autometer gauges Tach & Speedometer are Ultra-lite series The remaining are Lunar series (fuel level, oil pressure, water temp, voltage) AEM wideband sensor with gauge RCI seat harnesses Door panels & rear seats are in good shape (though not perfect) Headliner is in awesome shape compared to the typical 510 Dash Pad is near perfect (replaced it recently) Momo Steering wheel hub Sprint racing steering wheel (I may replace this with a Sparco) Exterior: Advan SA3R wheels, 16x7’s up front with 16x8’s In the rear BF Goodrich G-Force KDW T/A tires (nearly new) 205front, 225rear Hella/BMW headlight conversion with relays Hood shocks Carbon Fiber rear view mirrors Suspension/Steering: Koni Yellow’s in the rear with Ground Control Springs (approx. 950lbs.) Koni Red’s in front with 325lb Ground Control Springs, spare 275lb set 200sx V6 front struts Techno Toy Tuning tension rods Penultimate Rear crossmember Cusco Camber Plates Bumpsteer Spacers Techno Toy Tuning Spring perches with bearings up front Modified Rear LCA’s for added rear wheel clearance Custom Rack & pinion steering rack using a BMW manual rack (very nice/tight steering feel with no noticeable bump steer) Rolled fenders with a professional rolling tool Front Sway Bar (this is one thing that can/should be replaced with an aftermarket one designed to go in front of the oil pan) Brakes: Z32 4 piston Calipers in front with 11.5” vented rotor Z32 2 piston Calipers in rear Most of the Brake hardlines are new Stainless steel braided flexible lines Wilwood brake bias adjuster (in cabin) 280zx 15/16 Brake Master Cylinder Security: Python Pager Car Alarm JDM Removable Steering Wheel hub EXTRAS: 2 heads from a “Rev-Up” VQ35DE (1mm more lift on the cams & stiffer valve springs) Spare BMW/Hella headlights Spare BMW manual steering rack Royal Purple Trans fluid (enough for oil change) Spare bolts & parts from the engine Handbrake, cables, & Wilwood spot calipers (for E-brake conversion) Spare C pillar vents Front bumper Spare door hinges with new pins/bushings Fat Mat Sound deadening Additional spare parts that your typical 510 owner has As you can see, I have done about all of the performance, handling, drivetrain, & electronic modifications that you can dream of to this car. The only thing that remains to make this car perfect is body-work. The car is a good candidate for bodywork (not a rusted out shell) or you can transfer all of these parts onto an already done chassis. The body is fairly solid with dings here & there on the exterior, some holes in the floor pans (mainly Driver’s side, that can be spot repaired, does not need complete replacement), & a dented rocker on the driver’s side. The trunk is solid (not rusted out) & the rear tail light panel was replaced with fiberglass. The front passenger side fender was recently replaced & rattle-canned white to match the car for now, awaiting my future plans to paint the car. With some body work & some wire tucking this will be even more of eye turner than it already is. Buy this car, do the bodywork how you want it, and make it yours. The car is located in Salt Lake City, Utah & local pick-up is preferable so you can haul the extra parts off as well.. I will also work with a shipping company arranged by the purchaser. $9,900 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by xlr8n; 11-05-2009 at 09:38 PM. | |
| Sponsored Links | |
| | #6 |
| The track is where this car would really shine since it is so responsive with the nice flat torque curve of the VQ. It is a quick car, maybe not as fast as my new bosses 911 Turbo (that thing seriously slams you into your seat), but it could probably keep up with my other bosses M5. | |
| | #11 |
| If it very fast to accelerate and stop as well, it doesn't take much braking power to stop a lightweight car, but this car has a good amount of stopping power with the current brake setup to compliment the power it has. If we can figure out a way to get caught up on the bills I may manage to keep the beast. | |
| | #13 |
| It has the typical 510 grip. Meaning you can toss it into corners confidently, you just have to be careful how you apply the power (especially when cornering & this kind of instant torque) because abrupt power input causes the rear to squat, the camber changes quickly, then you're riding on just the inside edges of the tires, & grip is now minimal. Overall it gets good traction and grip since the Helical LSD helps, it just needs careful use the go pedal while turning. | |
| | #15 |
| New Month Bump | |
| Sponsored Links | |
| | #16 |
| One more try before I start to sell a few parts. If anyone is interested in the wheels and tires lmk, since they'll probably be the first thing I sell (easy to remove and replace, though it took buying 2 sets of Advans to get this particular offset combination). | |
| | #18 |
| Zilvia Addict ![]() | eBay Find of the Day: VQ35DE-powered Datsun 510 may be the perfect swap [w/VIDEO] — Autoblog lol
__________________ garysuk.blogspot.com |
| | #20 |
| Yes, there is no AC nor is there heater due to the mods I had to make to the trans tunnel. An OEM Datsun 510 heater core would still probably fit though with a little bit of plastic removal from the base of an OEM unit. | |
| | #23 |
| Thanks guys. If no one snags the complete car soon, I may begin selling some parts in a few weeks when I have a chance to pull things off. All I'll be selling though are: Engine Trans AEM EMS & engine harness Wheels with Tires If someone really wants the rear driveline they'll have to buy everything (crossmember, R200 diff w/ LSD, CV axles, modded LCA's, etc.) A lot of time & $ went into it so it's going to take a large chunk of change for me to part with it. | |
| | #24 |
| Zilvia Member ![]() | Well, If you change your mind, LMK, I really could only use the Helical LSD. I have an S14, so nothing else would work. I could exhange you my Diff for yours, so that way you still have a functioning rear end, just not a Limited Slip on.,,again,, LMK |
| | #25 |
| FYI, my 510 does have an R200 Diff, it's however a long nose R200 from a Z31 which is different than a shortnose R200 in your S14. We would have to swap the actual differentials inside (since the pumpkins are not the same). This really makes such an exchange impractical for both of us. You'd be better off snagging an LSD & dropping it in your diff, rather than I take mine apart. | |
| | #27 |
| I'm going to throw this out there and state I am open to trades, that include some $ on your end. Possible vehicles that I'm interested in: Another 510 S13 coupe Subaru Impreza Wagons (Stock or swapped, really like older GF8's) FD RX-7 4x4 pickups with cabs | |
| | #30 | ||||
| 244 ![]() | Quote:
__________________ | ||||
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/cars-sale/270832-1972-vq35de-swapped-datsun-510-a.html | ||||
| Posted By | For | Type | Date | Hits |
| Nissan guys: Prepare to drool - Page 2 - | This thread | Refback | 09-23-2009 08:03 PM | 10 |
