Old 02-17-2009, 04:19 AM   #1
kouki crisp's Avatar
1990 nissan 240sx silvia front built sr So Cal
I'm selling my 1990 nissan 240sx with silvia front which i have been dailying for the past few months. Due to some circumstances i must sell this car and i need the money. Always changed the oil every 2000 miles with Motul 5w30 with OEM filter! This car is very reliable and will not fail you. My friend andrew built this engine from the ground up and a couple of PROs can vouch for this car. Plus its a sleeper, i've had a few people surprised that i have a sr20 in there, basically cop friendly!
Only downside is i have damage on my driverside quarterpanel right next to the bumper which should be an easy fix. Thats why i lowered the price from 6500 to 5500.
And i have no power steering but can provide most of the parts to you, just need the ps lines.
Heres the list of mods on the car
Engine:
sr20 red top from an s13. with black top harness and ecu
circuit sports intake manifold gasket
nismo fpr
turbo xs exhast manifold
stock exhaust
stock turbo with adjustable wastegate and custom bracket.
the motor has all new oem internals on the bottom end ( pistons, conrods, and the crank was balanced and polished)
s15 motor mounts
s15 turbo manifold gasket
acl race bearings
greddy hotpipe
arp headstuds, rod bolts, and mainstuds
custom grounding kit that works great
individually grounded coilpacks
cometic headgasket
act street clutch rated at 362 ft lbs and light weight flywheel.
the head has bean decked as well as the block
the head internals have been replace with new factory ones. So new valve springs, cam blots, valves, retainers, and valve seals and lifters, and rocker arms.
also has a gt spec down pipe
yoshio factory radiator
new coolant temp sensor
new plugs ngk iridium 8s
greddy airinx intake
all new gaskets from nissan
new fuel lines from goodyear and vacume lines
new goodyear gatorback belt
new oem oil pump and water pump
nismo thermostat
300zx fuel filter
alternator pully
Suspension:
d2 coilovers
secchi tension rods
peak perfomance rucas
peak performance rear toe arms
energy steering rack bushings
viscous lsd with 5 bolt axles and a 4.1 final drive
nismo clutch pivot
Brakes:
300zx front calipers with slotted and cross drilled rotors
project mu break pads
nismo wheel stud
steel braided break lines
25 mm spacers( not pictured)
Interior:
nismo style steering wheel
nismo shiftnob
horn button
nrg quick release
momo hub
jvc cd player
blitz turbo timer
Only asking $5500 obo! Make an offer, you'd be surprised and i'll try to work with you!
So far this is the only picture i have, i'll take some more current ones!
If your interested or have any questions don't hestitate to PM or reply here since i'm always on zilvia! Only call me if your really interested in purchasing the car at (323)661-0301 jonathan
kouki crisp is offline
Old 02-17-2009, 05:31 AM   #2
Donesyboy's Avatar
may be interested = ]
you can call me prince
Donesyboy is offline
Old 02-17-2009, 12:42 PM   #3
wasn't Ihaslongtorso just selling this car? 1990 s13 coupe silvia front, rebuilt sr20 and more.
yellowfever180 is offline
Old 02-18-2009, 03:18 AM   #4
first bump, need to sell this asap!
Old 02-18-2009, 11:05 AM   #5
244
racerx2k1's Avatar
I'd like to know that too.
racerx2k1 is offline
Old 02-18-2009, 12:33 PM   #6
Cleanest coupe in la by a legit seller!
glws bro!
gripstr is offline
Old 02-18-2009, 05:54 PM   #7
244
racerx2k1's Avatar
This thread is closed until I hear from kouki crisp.
SEO by vBSEO 3.3.0
