| | #1 (permalink) |
| Leaky Injector | TW:fully built sr20det 1990 nissan 240sx testing water,has about 6k on the engine and all the parts.and about 100 miles on new daytona blue paint. i will consider to trade for 350z,g35 coupe,evo,sti,is300,s2k.clean s14. 15kobo 1990 fully built sr20det sil80 machine work(bell motor) block boro .020 over align bore/hone studes,and main girdle pin bore standard crank polish balance assembly resurface head resurface block stage 3 port and polished deck head 16 valve job replace freeze out plugs,oilgallery plugs. machined shop put the block and head together. engine cp piston 86.5 bore .020/compression 8.5/1 eagle rods,arp rod studs clevite bearing cometic head gasket 1.2mm arp head studes super tech duel valves spring 5 angle valve job hks 272 cams hks cam sprockets hks rocker arm stoppers greddy intake manifold stock injecters and maf new oem water pump new oem oil pump oem gasket kit oem 300zx fuel filter ngr spark plug rate 7 new nismo colder thermostat new oem wireing harness walbro 255 fuel pump koyo radiator flex alite fan with thermo switch samco hoes circuit sport over flow tank summit battery relocation kit greddy fmic v-spec custom hot piping gor greddy type r bov greddy cold piping auto lab custom intake piping rebuilt t25 with 4000 miles greddy 3" down pipe with custom 3" stainless steel cat back exhuast drivetrain exedy stage 2,3 puck clutch act lightend flywheel 1pc aluminum drive shaft(drive shaft shop) rebuilt j30 rear diff agency steel braided clutch line nismo transmission and engine mounts brakes/suspension front and rear 5 lug ichiba 300zx 30mm front brakes rebuild and powdercoated 300zx rear brakes rebuilt and powder coated 300zx rear drum kit pbr brake pads front and rear brembo rotors spl conversion lines 300zx master cylinder s14 abs brake boster ksports coilovers meagan control arm meagan toe meagan tension meagan traction wheels 5 zigens matt black front 18/8.5 30ofset rear 18/9.5 12offset interior s14 leather seats 180sx gauge cluster apexi boost gauge apexi safc tuned leather glove box leather center console with cup holder exterior hid kit 8000k silvia oem side skirts silvia oem rear aero bumper silvia oem fenders silvia oem square headlights 180sx rear lip valace 180sx kouki taillights before ![]() after ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() picture with out greddy intake manifold ![]() Last edited by kev240sx90; 09-01-2008 at 08:29 PM. |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
