Old 06-23-2012, 06:32 PM   #1
1UZ V8 Coupe POW! (Slow Build)
starting a new project and ill update as i go. been collecting parts for sometime now. trying to buy parts here and there, tried to gather what i needed then put together.
Started off with a 91 Coupe with a KA24DE
Picked up a ls400 1uzfe motor from a dismantler in Rancho Cordova, CA
And started taking things apart.
First thing done was new timing belt
Got the Bottom crank at TDC:
L&R cams:
Dont mind the belt marks
New belt aligned:
New gasket kit (i will only be using a few things from this)
And here are all the parts i Have ready to go:
I Knew i wanted to go with a KA trans bc of how easy they are to find, and the 5 speed gear box i think will be good with this motor. plus i dont need a new drive shaft or trans mount.
So research led me to getting the following.
1uz to KA trans adapter plate
w/ TOB spacer
MR2turbo flywheel (Same spline count as KA trans)
300 zx Clutch Disk (Same surface area as flywheel)
I gave Brett Collins a Call and ordered what i needed.
BEEEFY! plate
And TOB Spacer w/ other parts such as
Injector seals
PBM coolant temp sensor housing thing
PBM shift Knob
repda916 is offline   Reply With Quote
Old 07-31-2012, 05:26 AM   #2
moar!. did you have to get or make new motor mounts? or does the 1uz line up with stock ka24 mounts? Powersteering? a/c?
Sirius is offline   Reply With Quote
Old 07-31-2012, 08:54 AM   #3
mishimoto's Avatar
That adapter plate looks well made! Subscribed for more updates.
Brian K.
mishimoto is offline   Reply With Quote
Old 07-31-2012, 09:34 AM   #4
did you need to get a new pivot ball? Also, did you get the trans machined to make up for the extra thickness of the adapter plate?
F/S: Stoptech-HKS-Tomei-Greddy-350z+240sx Parts...TONS MORE!
Imarvin240 is online now   Reply With Quote
Old 08-01-2012, 01:41 AM   #5
jdm2191's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
1UZ FTW curious on the install
jdm2191 is offline   Reply With Quote
Old 08-30-2012, 12:42 PM   #6
Had a chance to work on this thing.
Got You can see how i had the machinist mill around the center crank bolts to use the oem plate as a pressure plate to distribute the pressure evenly on the bolts
Used ARP 4ag flywheel bolts.
clutch and pressure plate mounted up
I wanted to really feel this thing when i kicked the clutch, 2500lb pressure plate:
Next i had to fix the starter clearence issure so i removed the stock starter bolts and added a spacer to the inside to push it back about 3mm.
now it has enough room to engage and not rub when not.
I than sat the engine the bay to start figuring out the motor mounts,
This is where i left off but you can see what need to be done. That hump is the Xmember.
And this is the room i have
Old 08-30-2012, 01:08 PM   #7
Okinawandrifter87's Avatar
Way to represent Sacramento, subscribed for updates! Man I can't wait to be back in Sac.
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 08-30-2012, 01:18 PM   #8
Flicktitty's Avatar
Send a message via AIM to Flicktitty
what mounts are you using? are you doing your own wiring?
Very interested!
1989 240sx SE Coupe, 19k Original miles, 2JZGTE, PT6266,Fuel System, AEM V2, Sound Performance Tuned
www.Wi240sx.com | http://flicktitty.tumblr.com
Flicktitty is offline   Reply With Quote
Old 08-31-2012, 12:51 AM   #9
For mounts I was going to make my own but we just
Moved into a new house and to keep the cutting and grinding noise
Down until I get to know the neighbors i ordered them from enjuki (sp)
Now as far as wiring that's something I don't want to mess with so
I'm trailering the car to Livermore, Ca where
I found a guy that can wire it.
He's done a lot of 1uz swaps and even bar'd theM
But I'm not doing all that since I took off all egr and headers
Are beyond oem.
I'll make a wiring guide once I get to that point to help you all out.
Old 09-04-2012, 04:46 PM   #10
UPDATE:
Looky what i got:
If Anyone needs motor mounts for the S13 to 1uz let me know! ill be making some for half the price.
Old 09-05-2012, 05:35 AM   #11
Cool build bro! If I wasn't going 1J I'd be all over this! Honestly at times I thought about selling it and doing the 1UZ. But I've got mounts wiring etc. already... maybe one day.
Minz is offline   Reply With Quote
Old 10-28-2012, 01:21 AM   #12
sub'd in for updates
speeddream is offline   Reply With Quote
Old 10-28-2012, 12:50 PM   #13
RastaS14's Avatar
It's good to see another person venturing with this swap. The 1UZ is a great motor and they are dirt cheap! You going to keep it stock/NA or what are your goals with it?
RastaS14 is offline   Reply With Quote
Old 11-05-2012, 07:50 PM   #14
Awesome choice of motor man.
food7373 is offline   Reply With Quote
Old 11-08-2012, 07:42 PM   #15
In time-out for misbehaving.
Need some updates man! The 1UZ is great and sounds amazing haha
Mofuhcka is offline   Reply With Quote
Old 11-14-2012, 08:16 PM   #16
hey u think i can get the guy that's doing ur wiring done? i just to know how much he would charge. i cant decide whether or not to go 302 or 1uz. i dont care jus want a legit v8 job done.
wackintheballs is offline   Reply With Quote
Old 11-15-2012, 12:42 PM   #17
Following as i'm pursuing the same swap in CA
motorsporttc is offline   Reply With Quote
Old 11-15-2012, 01:48 PM   #18
Allwayssideways's Avatar
5.0 swaps done right are bad ass
Allwayssideways is offline   Reply With Quote
Old 11-15-2012, 04:37 PM   #19
budgetdrifter's Avatar
Going to be trying this swap within a month on my currently heartless s14 then proceed to take it off non op!
bump for pictures and for being in Cali!
budgetdrifter is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
