Old 08-03-2010, 06:57 PM   #1
scottie's Avatar
1990 S13 Coupe Build
I will let the pictures do the talking. This project has been going on for longer than I care to remember. Hope you guys enjoy!
Started with......
Media Blasted
Rust Inhibitor
Fitting Body
Accusump Mount
Origin Lab Doors w/Custom Aluminum Backing Plate
Powerplant
Speartech Harness
Interior
Test Fit
GTO Pedal Setup
PRC LSx Radiator w/Custom Aluminum 12" Dual Fans
Suspension Components
Sikky Mount Kit
Painless Chassis Harness.....
More to come...
scottie is offline   Reply With Quote
Old 08-03-2010, 06:58 PM   #2
scottie's Avatar
Dash Solution.....
(the old setup)
(new setup)
Its now in the capable hands of Broadfield!
To be continued........
Old 08-03-2010, 09:30 PM   #3
Looks absolutely bitchin!
stone184 is offline   Reply With Quote
Old 08-04-2010, 09:36 AM   #4
CamryOnBronze's Avatar
Trader Rating: (112)
Feedback Score: 112 reviews
Send a message via AIM to CamryOnBronze
WOW, awesome!! Mad props!
CamryOnBronze.Wordpress.com
CamryOnBronze is offline   Reply With Quote
Old 08-05-2010, 12:02 PM   #5
scottie's Avatar
Thanks man! I love your build as well. Very simple and detailed. Looks factory yet you know its modded by the overall look/feel. I know mine is completely different so thanks for the encouragement! Hopefully I will have some useful updates in the near future.
Old 08-25-2010, 09:50 AM   #6
scottie's Avatar
Well the car isnt going to be done for a while at the body but the cluster is finished. HUGE THANKS to Broadfield for his services.
This Setup will Monitor:
RPM
MPH
Gear Selection
ECU Codes
Oil Pressure
Fuel Pressure
Oil Temp
Coolant Temp
Wideband A/F (left)
Fuel % (right)
Time to enjoy a beer
Black Label LS2 Rails
Old 10-08-2010, 09:23 AM   #7
scottie's Avatar
Custom Bash Bar (tandem drift protection)
Sikky Kit Installed
Old 10-10-2010, 08:07 AM   #8
I love it<3
Csomme is offline   Reply With Quote
Old 10-11-2010, 10:10 AM   #9
Send a message via AIM to Black240Ct
awesome.. have any pics on how you mounted the bash bar to your car?
Black240Ct is offline   Reply With Quote
Old 10-12-2010, 08:27 PM   #10
scottie's Avatar
I dont yet. Once I can get the whole car back to the fab shop, I will post pics of how it will mount. Its pretty simple but hard to explain. Basically going to use base plates and slip fitting to hold the bash bar in place.
Old 10-13-2010, 03:53 PM   #11
K_style's Avatar
Trader Rating: (51)
Feedback Score: 51 reviews
Awesome build !!!
Subscribed !!!
Old 10-14-2010, 07:50 AM   #12
scottie's Avatar
I installed the injectors & engine harness.
My plan is to route everything to the driver's kick panel. The fan relays, injector relays/fuses and ecu will go in the inside panel where the oem chassis fuse block was locatrd. The new painless harness is "planned" to be mounted in the center under the armrest. This way I can avoid having pesky passengers accidentally kicking my sh*t.
Old 10-14-2010, 06:53 PM   #13
badbob2121's Avatar
wow, i love everything i see. broadfield did a great job like always. you are dropping a pretty penny on this coupe.... im sure it will be worth it!!!
SR-GT2871
Smiles per gallon > Miles per gallon
badbob2121 is offline   Reply With Quote
Old 09-09-2011, 11:43 PM   #14
scottie's Avatar
I couldnt decide what I wanted to do with the dash.... leave it alone, wrap it, new vinyl...... then I said Flock it and ordered this....
Seibon CF trunk and Nismo Power Brace. Just more stuff to get me closer...
And simply one of the coolest gadgets to simplify the wiring and my well being as a result. The ARC flat touch panel is killer.
Old 09-09-2011, 11:47 PM   #15
scottie's Avatar
Since I decided to leave the wide body panels exposed (not molded) I wanted to make it easy to remove buy using bolts vs rivets. And of course you cant just go down to ACE Hardware.
And another much larger box showed up with nothing written on the outside. Hhhmmmm..
Hhhmmm.....
Still not ringing a bell
Ah Ha! Now the wheels are turning...
Old 09-25-2011, 05:54 PM   #16
scottie's Avatar
And it begins....
Old 09-29-2011, 01:03 PM   #17
scottie's Avatar
So you want Origin Doors for your S13? There is some work involved. It seems like this is one of the hardest subjects to locate information & pics on. Enjoy.
-Scott
Old 09-29-2011, 02:07 PM   #18
scottie's Avatar
Floor pan cut, sectioned and sealed to get my seat as low as possible.
Old 09-29-2011, 07:53 PM   #19
Awesome build man! Keep the updates coming!
CLM_s13Type-x is offline   Reply With Quote
Old 09-30-2011, 09:47 AM   #20
scottie's Avatar
Car still weighs too much...
Old 10-03-2011, 07:00 AM   #21
scottie's Avatar
Old 10-03-2011, 11:38 AM   #22
Wow! This is going to be one awesome car!
Old 10-03-2011, 01:53 PM   #23
scottie's Avatar
Thanks for the kind words. If you approve I must be on the right track cuz your car is super clean. One of the few hatches (actually only 3) that I really like/ would own.
Old 10-04-2011, 06:21 AM   #24
scottie's Avatar
Hard to resist good head(s)
More to come....
Old 10-05-2011, 06:25 AM   #25
va240dude's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
Wow, really impressed with all the quality work, parts, and the fact you do everything yourself. Mad props man.
日本語を勉強している。
va240dude is offline   Reply With Quote
Old 10-05-2011, 09:24 AM   #26
scottie's Avatar
Thanks man!
I am going to try this whole fuel cell thing one last time. This one is approved by FIA, NHRA, NASA and pretty much any other racing body.
Big THANKS to Jeremiah for suggesting the Aluminum version. Saves 13lbs over steel and looks pretty cool. It has an internal sump with 3 check valves to ensure pickup always has fuel to the last drop. The leveler is calibrated for GM type output and remote filler neck can be clocked any direction.
Hopefully today I can begin with replacing the cam, timing chain and pump. I left her naked last night.
Old 10-06-2011, 01:54 AM   #27
scottie's Avatar
Comp Tru Union pressed into GM rockers ready to go.
LS2 (left) vs LS7 (right) Lifter. Notice how the bearing is better enclosed on the LS7? Soaked in oil for a few hours before install.
"Cam" You Dig It?
Setting the timing properly did help on the reinstall. ARP bolts, Melling Oil Pump and C5R chain.
ASP Pulley went on rather surprisingly smooth!
Well I am dead tired.
Old 10-06-2011, 09:04 AM   #28
So nice dude!
Old 10-07-2011, 12:51 AM   #29
scottie's Avatar
So nice dude!
I should have never made the call to SPL........
Old 10-07-2011, 07:53 AM   #30
It just keeps getting better, haha. SPL stuff is so nice- I'm a believer now for sure, haha.
SEO by vBSEO 3.6.0 PL2
