Old 08-30-2002, 05:41 PM   #1
Can somebody give me a wet site,  or tell me about the advantage or disadvantage of AWD cars, and how they compare to FWD and RWD.
Thanks.
logo20 is offline
Old 08-30-2002, 05:54 PM   #2
well obviously the advantage of an AWD car is all 4 wheels are pushing/pulling the car, the disadvantage is because it has a larger drivetrain you loose more horsepower in it, and you will find an awd drivetrain will take less horse power before major modifications need to be done to it due to the extra load on the transmission and of course the transfer case.  And a awd car is awesome in the winter.
i dont know what advantage a fwd car has over other cars for racing, prolly none, better in snow though....
the advantage of a rwd car is that when you lay into and the car is pulling forward the weight "transfers" to the back of the vehicle giving you more power to the ground being that the "extra gravity" is pushing the wheels down harder. Unfortunatly the rwd's are obvoiusly the worst in wlippery conditions.
Matt
"andy offers kevin pudding at 9, if andy is 7 years older then pudding than how many liters of andy does it take to get to detroit?"
"There are 3 types of people in this world. People who can count, and people who cant.."
""Save the Whales" (Trade them for valuable prizes)"
Mtt22 is offline
Old 08-31-2002, 12:05 AM   #3
This question is too vague to give a proper response to, but I'll try anyway.
Despite popular opinion, without active diffs or a heavy rear torque split, AWD sucks on dry pavement.  If you don't believe me, watch a WRX at an autocross, either stock or modified.  They basically drive like a overweight FWD car except they understeer a bit less on the exit.  It takes some real manhandling or a huge rear sway bar to break the end loose.  I regularly outrun them in my s13 despite being down around 75 hp simply because I can stay on the throttle longer.  Great for dirt/wet asphalt/drag racing though.
orange-grey is offline
Old 08-31-2002, 01:13 AM   #4
Send a message via AIM to guidot
Here it is:
FWD - Loss of power through driveline is minimal.  Steering and power is put through one area.  Heavy understeer in corners.  Weight distribution is usually heavy in the front.
AWD - Greatest loss of power in driveline.  More stable under uneven road conditions.  Mild understeer.  Weight distribution is medium-heavy front.
RWD - Moderate loss of power in driveline (10% stock 240).  Steering and power are put down separately (better turning radius, higher sensitivity to movement).  Low understeer to moderate oversteer (depending on car).  Weight distribution is almost as close to 50/50 as possible.
Midengine - Loss of power similar to fwd.  Steering and power are separate.  Neutral to heavy oversteer (best agility of all).  Weight distribution is even or rear heavy.
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline
Old 08-31-2002, 11:35 AM   #5
Send a message via Yahoo to gemoose23
Back in September of 2000,
Sport Compact Car did an Article about this.
Sport Compact Article, RWD, FWD, and AWD...
The Eclipse was tuned by where I work... RRE.
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Some good reading, enjoy.
GeMoose23
92 GSX
91 240sx
00 TL1000R
gemoose23 is offline
Old 08-31-2002, 07:03 PM   #6
240 loses about 17% through driveline.
piratepete420 is offline
Old 09-01-2002, 02:40 PM   #7
Married to the Mob
S13Grl's Avatar
I think this should be archived. Correct me if I'm wrong please.
And 240s lose between 10-15%, depending on vehicle conditions.
S13Grl is offline
SEO by vBSEO 3.3.0
