| Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback. |
| | #1 |
| Users Awaiting Email Confirmation | FuelTech FT 400 FT 400 STAND ALONE Fully Programmable Fuel Injection with distributor type or distributorless Ignition control. 4.3" TFT Dashboard This is IT. The unit you see is a complete standalone no other boxes, programmers, or displays needed. You do not even need a laptop you can tune from the Color Touch screen. Link to the Site FuelTech Complete CAN communication: firmware update, FuelTech CAN network connection and FuelTech Computer Software - ECU Manager, to ECU configuration and tuning FuelTech Fuel Automapping (requires external WB-o2 Conditioner) Closed Loop Lambda Control (requires external WB-o2 Conditioner) A link to Buy Fuel Tech | FT400 EFI Resources: Maximum RPM: 16000rpm Built-in MAP sensor for naturally aspirated or blown engines (6bar - 87psi) 1 to 12 cylinders engine management Real Time programmable 4.3” touch screen TFT Sensors Input: Engine coolant temperature (oil or water) Intake air temperature Oil pressure Fuel pressure Oxygen Sensor (narrow or wide band) Air Conditioning Control Configurable Auxiliary Outputs: Progressive Nitrous Injection with fuel and ignition compensation (activated by TPS) Electronic boost control through 3 way PWM solenoid valve (activated by RPM and TPS) Fuel pump control Variable camshaft control (VTEC) Powerglide transmission shift (2 speed) Electric fan by coolant temperature Idle speed valve/stepper motor control External shift light control Air Conditioning Control Ignition Control: Compatible with hall effect distributor or crank trigger wheels: 60-2, 36-1, 12-1, 3, 4 or 8 tooth wheels and more. Distributor, wasted spark coils or coil on plug 5 ignition outputs Hall or magnetic trigger input Time Based Rev Limiter (Traction Control) Two-Step rev limiter with timing retard and fuel enrichment Ignition and/or Fuel Rev Limiter Ignition Coil Dwell time control Ignition outputs to MSD, FuelTech SparkPRO, Integrated HEI Coils and built-in ignitor coils Total Fuel Injection Control: Normally aspirated engines by TPS, MAP+TPS or MAP only Turbocharged, supercharged or blown engines by integrated MAP Up to 2 injectors banks with individual maps Up to 12 high impedance injectors or unlimited with FuelTech Peak and Hold Driver Fuel Injection Automapping and Closed Loop Lambda Control: Fuel maps automapping using wideband oxygen sensor. Closed Loop Lambda Control. Advanced Idle Speed control: Target idle speed control by engine temperature Air and ignition timing advanced algorithm control PWM valve solenoid output Stepper Motor output Drive-by-wire control – Electronic Throttle Body: Idle speed control Throttle speed mode adjustment (slow, normal and fast modes) Complete and easy tuning: Overall trim function for Fuel Maps (individual by bank) and Ignition Maps Interpolated Ignition Maps per RPM, with individual compensation maps: vacuum, boost, TPS, intake air temperature and coolant temperature. Interpolated Fuel Injection Maps per TPS or MAP, with compensation maps by: RPM, intake air temperature, coolant temperature and battery voltage. Anti-Lag Systems Deceleration Fuel cut-off Adjustable engine start fuel injection time by engine temperature and ignition timing Security and user resources: User protection password Tuner protection password Injectors dead time configuration to real fuel injection time processing Check Control Warnings: exceeded boost pressure, RPM, coolant temperature, fuel injectors opening %, oil pressure, fuel pressure. Adjustable LCD Display brightness Customizable start screen message Up to 5 memories to save different maps adjustments Complete TFT Dashboard with real time ECU information Last edited by Z33@S-MAX; 02-02-2012 at 09:18 AM.. |
| Sponsored Links | |
| | #6 | |
| Users Awaiting Email Confirmation | Quote:
BTW the manufacture is offering a crazy special install of the unit and dyno for only $600 | |
| | #8 |
| Users Awaiting Email Confirmation | FT300 is $1199.00 FT400 is $1799.00 Full color touch screen display Both units come with a unterminated harness . All you need to do is use your existing connectors from you OEM harness. Shipping is $30-40 due the the insurance. |
| | #9 | |
| Zilvia Junkie ![]() Join Date: Mar 2007 Location: Glendale, AZ
Trader Rating: (20) Feedback Score: 20 reviews | Quote:
where is the installer located? | |
| | #10 |
| Users Awaiting Email Confirmation | |
| | #11 |
| 2JZ NO SHIT ![]() Join Date: Apr 2007 Location: Wi240sx.com Age: 25
Trader Rating: (10) Feedback Score: 10 reviews | So this runs some sort of flex fuel sensor?To go from E85 to 93 to C16 that will auto adjust when you put the fuel in? Or do you need to get a TUNE for E85 / 93 / C16 then switch over via a switch. Also does this have a traction control function? Can it control an automatic?
__________________ 1989 240sx SE Coupe, 19k Original miles, 2JZGTE Swapped www.Wi240sx.com | http://flicktitty.tumblr.com |
| | #12 | |
NO labtop is needed. The handheld unit is the complete Standalone. Just a few buttons too press and you can flip between 5 different maps. Each fuel will need its own tuned map. YES it has traction Control! FuelTech | |
| | #13 |
| Leaky Injector | I'm looking to purchase a standalone in the next week or so for my 2JZ VVTI in a S14 driftcar. I'm torn between the FT300 or 400, AEM V2, and a Haltech. Could you give me the benefits or similarities of the Fueltech over some of the other units mentioned? Would you recomend this unit over the others? If so why? Thanks, Matt |
| | #14 | |
| | #15 |
| Leaky Injector Join Date: Feb 2008 Location: north Jersey Age: 40
Trader Rating: (1) Feedback Score: 1 reviews | FuelTech Dyno Day March 17th @ ProFab Chassis (Question & Answer Seminar) All are welcome, complementary food and drinks Learn about a new cutting edge standalone EMS from the manufacture We’ll even do the install for you!!! Drop off your car BEFORE MARCH 14th and pick it up with your FuelTech EFI unit installed and dyno tuned on the 17th for only $600.00 You will need to purchase a FuelTech unit (FT200, FT300, FT400) on or before the install date of March 14th. Link for purchase of Install and tune: (FuelTech :: FuelTech Manufacturer Install and Dyno Session March 13th - Speed Max Performance - Store) Dyno and instructional secession will be held at ProFab Chassis on the 17th of March 10, 2012 @ 27 Ridge Road Whitehouse Station, NJ 08889 www.profabchassis.com Contact us with any questions. 973-891-1755 Vehicle must be dyno ready. |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
